Whats squeaking?
Old Apr 10, 2013 | 03:15 PM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
Default Whats squeaking?
Ok So I got my 95 Jimmy, I noticed that I have squeaking when I'm driving. I jacked it up and spun the tire and listened and it sounds like its coming from where the CV shaft connects to the differential. I thought that was kind of weird so here I am. When I break it stops squeaking but any other time it's squeaking, turning or bumps do not affect it. Could it be that I need a new CV shaft or something inside the differential is going bad? I don't know how applying the breaks could affect this.... Help?
Old Apr 10, 2013 | 03:26 PM
richphotos's Avatar
when you brake it stops, I would guess it has something to do with your brakes
Old Apr 10, 2013 | 04:16 PM
Diaita's Avatar
Perhaps the squealers on the brake pads? Front brakes may need replacing.
Old Apr 10, 2013 | 04:25 PM
So it might just be the breaks? even though it sounds like its coming from around the diff?
Old Apr 11, 2013 | 01:19 PM
Diaita's Avatar
It is possible. It's a quick check to rule it out, and pushing the brake pedal makes the squeal go away. It's where I'd start.
Old Apr 11, 2013 | 04:26 PM
rexazz2's Avatar
+1
if the sound goes away when braking check your pad thickness
Generallyyou can bend the squealer tab away but then you get no more warnings
Old Apr 11, 2013 | 05:26 PM
Diaita's Avatar
Originally Posted by rexazz2
+1
You could bend the squealer out if you are only driving to the auto parts store to buy new brake pads!
Miller
May 9, 2007 06:02 AM
kennysgirl
Aug 11, 2006 12:48 PM
jumper02
Jun 8, 2006 12:09 AM
blazerman
May 29, 2006 10:39 PM
tpendergraft85
Feb 17, 2006 07:10 AM
