ZR2 rear end in a non Z
Well, im in the process of putting a ZR2 rear end in my blazer. I got it all in and bolted down and found out that the driveshaft wont bolt together good. It will bolt together but there is a lot of slop because the u-joints are different. My question now is can I swap the yoke between the two rear ends or do I have to buy a new driveshaft? If i need a driveshaft will anyone work out of a ZR2? Im guessing that it would have to have an NP8 tcase like mine.
Get a conversion joint.
ZR2 specs:
Dimension : 1.19 x 1.19 Brg. Dia. x 3.62 x 3.62 Overall Width == 1350 Spicer
Non-ZR2 specs:
Dimension : 1.13 x 1.13 Brg. Dia. x 2.37 x 2.37 Overall Width == 2-3011 Saginaw S44
*EDIT* - The Neapco 2-1153 conversion joint is what you want. Advanced Auto sells Neapco (or so their website says) - $25.
Those looking for other conversion joints, check out Neapco's catalog at Neapco.com
ZR2 specs:
Non-ZR2 specs:
where might i find one of those? I was autozone for 30min while the guy was trying to make something work by swapping different caps. Which didnt work
Check out the edit above.
Thanks kyle. I will have to go get one in the morning
brino1
02-25-2011 08:05 PM
Spectreblazer
02-13-2010 04:59 PM
