ZR2 Steering gear symmetry
Old Nov 1, 2025 | 05:18 PM
blkblazerzr2's Avatar
blkblazerzr2 is on a distinguished road
Angry ZR2 Steering gear symmetry
Have a ZR2 jimmy. Trying to replace steering gear. Have a cardone 27 7559. The gear symmetry with the engine off is equal lock to lock. The symmetry with the engine running is unequal. It turns about half a turn more to the right than to the left. Is this normal? The steering wheel is centered the toe is close to spec the castor and camber have not been touched. The gear was turned lock to lock and then half way back before install. The left front tire digs into the sway bar on full right turn. Bad steering gear? Flushed the system, using gm fluid.
Old Mar 23, 2026 | 12:22 PM
I have since found out that apparnently there are different versions of BBB industries 5030139 and Cadone 277559 same part numbers but the gear has to have ZR2 specific calibaration so it has the correct stops internally. I tried useing microsoft co pilot but get contradictory results on part numbers. I am trying to find the correct version anyone car to comment.
Old Mar 25, 2026 | 09:36 PM
AJBert's Avatar
Wish I could help but I don't have a clue. Maybe check out the tie rods and see if one side is longer than the other. Could be the steering gear isn't clock right.
Old Mar 26, 2026 | 12:32 AM
You might try contacting a vendor that specializes in steering gears such as RedHead Steering Gears. You might even find info on their web pages that help.
Old Mar 26, 2026 | 08:02 AM
It's a mechanical system with power assist. The only way that I can think of that symmetry can be affected with the vehicle on versus off would be if pressure or just fluid is feeding into someplace it should not be inside the housing and hydro-locking it on one extreme meaning that it cannot escape to allow the gear-train to move fully to its extents as it typically should while not under pressurized operation. This would be a mechanical (well, hydraulic) defect in the unit itself in my opinion. If you feel that it warrants removal and return you should probably discuss it with the location you purchased it from prior to removal though just to make sure that you are going to be covered by the original warranty.
The sad state of affairs is that most of the available parts are not of very high quality any more.
Old Apr 13, 2026 | 11:22 PM
Well after trying three gears all do the same thing turn more to the right than to the left with engine running. Apparently The Zr2 4wd drives uses the same gear as the Non Zr2 4wd. I guess Microsoft Co pilot was incorrect?? The problem is solved by replace sway bar links I guess the bushings were bad.No more tire rubbing on sway bar. Must be normal for the steering gear to travel more to the right than to the left when engine on as all three gears did it. Thanks for the replys.
sticksboss
Feb 1, 2025 09:03 PM
christine_208
Nov 6, 2023 04:32 PM
Clayton64
Jan 9, 2020 01:27 PM
Coz2122
Jan 23, 2014 02:31 PM
Easy 8
Jan 2, 2008 06:58 PM
