Street N Strip Post your vacation driving stories, day at the track, breakdowns, safety issues, driving techniques, unique driving conditions, etc. STREET RACING STORIES ARE STRICTLY PROHIBITED.
Engine swap.. need advice
Old Mar 26, 2007 | 11:57 PM
Dombrus's Avatar
Dombrus is an unknown quantity at this point
Default Engine swap.. need advice
I have a 93 Blazer with a 4.3 vortec.
Currently the engine is in pieces and in need of a rebuild. All the parts are withing tolerance, as I checked them.
I had sent the heads off for a rebuild as well as he block that needed a deck job. While I was at the shop the guy showed me an engine that he had pulled out of a 99 s-10.
It was also a 4.3 vortec, but it had a supercharger, and a custom computer with the complete engine harness for under the hood. Also included are a rear wheel drive tranny and a foll flow muffler. He had pulled it out and swapped it with a later 5.7 longblock.
I know that I can put the engine in without any problems and get the car to run with that engine, the problem that I am running into is that the computer is a chip modded 99, and will not hook up to the dash of the 93.
Am I going to have to rig up the outputs from the 99 PCM to the 93 dash?
Or will I have to get a 99 dash and rig that into the 93 I have now?
Old Mar 27, 2007 | 10:03 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: Engine swap.. need advice
The only advice I have is that if it has vacuum lines, tag them and be careful with them. They break easily and if you don't know where to put them back, you'll need a proffesional mechanic to set it back right. Other than that, clean the engine really good before you put it back in.
Old Mar 29, 2007 | 12:10 AM
Dombrus's Avatar
Thanks...
I am a professional mechanic, I just haven't worked on this paticular model before...
But I will not be putting that engine in anyway.
Old May 21, 2007 | 08:32 AM
vagnozzi's Avatar
vagnozzi is an unknown quantity at this point
what kinda supercharger? I'm assuming its the Vortech 02-xx?
turbowubz
Feb 9, 2014 08:42 PM
BGesell
Jul 27, 2011 03:34 PM
JQP
Apr 30, 2011 09:27 AM
rcravincase
Sep 13, 2009 07:58 PM
soundguy
Sep 13, 2007 03:40 PM
