Suspension Tech Have a question about modifying your suspension? Ask it here.
2005 blazer lift kits??
Old Mar 7, 2015 | 09:53 PM
Shandell's Avatar
Shandell is on a distinguished road
Default 2005 blazer lift kits??
I have a 2005 blazer base model, 4wd, 2 door. I am looking for a 4-6 inch suspension lift online. just wondering if anyone knows where I can find one? I could only find a 2.5 inch on rough country.
Old Mar 8, 2015 | 12:52 AM
LeWhite's Avatar
4/6 inch lift will surely screw your front end geometry.
Old Mar 8, 2015 | 10:01 AM
Shandell's Avatar
So the 2.5 inch would be the way to go then? With a body lift? Sorry I know absolutely nothing about this kind of stuff so any advice would be greatly appreciated.
Old Mar 8, 2015 | 10:02 AM
rexazz2's Avatar
the 2dr will likely cause drive shaft angle problems
2.5 suspension + 2 body ???
Old Mar 8, 2015 | 01:06 PM
lazyboyjake's Avatar
lazyboyjake is on a distinguished road
I would say go with the 2.5 suspension and a 2 body. That's generally the common setup and will get you in the 31" tire range.
Old Mar 8, 2015 | 04:38 PM
Jamaroon's Avatar
search for a 2004, you might have better luck. a lot of websites only list up to 2004 for Blazers.
Old Mar 9, 2015 | 12:44 AM
clinthedding's Avatar
clinthedding is on a distinguished road
You can clear 32x11.50 with some tbar crank will rub at full lock on stock rims
Old Mar 9, 2015 | 08:16 PM
rexazz2's Avatar
konfettix13
Lifting Tech
Feb 16, 2014 10:59 PM
green dot
Nitrous, Super Chargers, & Turbos
Nov 16, 2012 02:34 PM
SmoyMoose
Mar 30, 2010 07:41 AM
03blazertucker
Lifting Tech
Feb 10, 2010 07:24 PM
97blz4x4
Suspension Tech
Nov 14, 2006 01:21 PM
