Suspension Tech Have a question about modifying your suspension? Ask it here.
97 blazer sas questions
Old Mar 29, 2018 | 09:52 PM
pacecountryboy's Avatar
pacecountryboy is on a distinguished road
Default 97 blazer sas questions
I have a 97 4dr 4x4 blazer Iam doing a sas on. I have access to sets of jeep wagoneer axles. But I would like to run the rodeo rear axle what year axles should I look for off the rodeo. I work at a auto salvage yard so I have access to all kinds of part and axles just trying to figure what will work for what Iam wanting to do. And I heard you can take the lockers off the rodeo and put them in the front jeep axle also I just want to make sure I don't forget anything. Any help would be nice and yes I have googled it a few different times but couldn't really track down what year axles I need to be looking for thank alot or any help
Old Mar 30, 2018 | 11:44 AM
chevyriders's Avatar
93+ rodeos have the disc brake Dana 44 rear end from what I've heard. I'm not sure about swapping a rodeo diff to the front waggy axle though...some dana44s have reverse cut gears and some don't. I forget which has which.
Old Mar 30, 2018 | 06:16 PM
thanks for the input Ian gonna do a little more research and try and see what I can come up with I have a guy I know that owns a company that builds custom drive shafts and builds axles Ian gonna give him a call and see what we can find out I'll let you know what I figure out
Old Sep 15, 2018 | 10:00 AM
awesomeamerican1's Avatar
awesomeamerican1 is on a distinguished road
I don't believe the diffs will swap. They are both standard rotation 44s and I believe you can use the ring and pinions but not sure on the carriers. From the research I did before considering this route, you should be able to transplant the e-brake and disk brake set up from the rodeo axle to the waggy axle. I didn't go this way and just used weld on brackets so I could run larger calipers and have the same ones all around.
Kpearson
Aug 22, 2014 12:25 PM
SLOWnSTEADY
Dec 16, 2012 10:26 AM
stevemccalister
Dec 9, 2012 06:14 AM
BigEffingHammer
Mar 5, 2012 09:14 AM
sasquatchfound
Jul 15, 2007 05:23 PM
