Suspension Tech Have a question about modifying your suspension? Ask it here.
Better Handling....?
Old Mar 26, 2009 | 07:39 AM
danracer's Avatar
danracer is on a distinguished road
Default Better Handling....?
Hi, I have an '01 blazer stock height with 235-75-15 tires...i want better handling and smoother ride. Right now its bouncy and a bit rough, streets here in Puerto Rico are not the best so i want a less jumpy ride. what is the best thing i could do?
Thnx, Daniel
Old Mar 26, 2009 | 09:03 AM
rriddle3's Avatar
Your truck has a fairly stout spring rate on it. Combine that with a wheelbase that is on the short side and a slightly narrow track width and you get a stiff, bouncy ride. Chevy designed these trucks with the idea of keeping the wheels firmly planted on the ground.
Old Mar 26, 2009 | 12:22 PM
Like Rich said, these trucks have a fairly heavy suspension to them. They are not made to ride like a car. You can change this to a certain extent with softer shocks. Your shocks are probably shot anyway as it should not be bouncy at all. I would start with new shocks and go from there.
There have been a few threads discussing shocks in the past so you should be able to find recommendations with a quick search.
Old Mar 26, 2009 | 02:03 PM
danracer's Avatar
ohhh i see thnx i'll check them out. i also want to lower it probably a 3/3 or a 4/4 do i have to notch the back? and would that weaken the frame?? thnx again
Old Mar 26, 2009 | 02:07 PM
No idea on the lowering thing...
Old Mar 26, 2009 | 05:50 PM
danracer's Avatar
ohhh okay thnx anyways
chris015
Engine & Internal
Jul 25, 2011 09:13 PM
88s10Blazer
Jun 6, 2010 12:36 AM
BrianMichaels1
May 17, 2008 10:43 PM
95LS
Suspension Tech
Mar 28, 2008 01:42 AM
lionel2
31
Mar 14, 2008 09:58 PM
