Suspension Tech Have a question about modifying your suspension? Ask it here.
lift kit/handling ability
Old Mar 26, 2008 | 11:16 PM
95LS's Avatar
95LS is an unknown quantity at this point
Default lift kit/handling ability
i am considering putting a lift kit on my truck (no time soon this is down the road because i have more important stuff to do to it) i dont think a 2" lift kit would do much and i would be better off getting at least a 4". i would do a suspension lift over a body lift (maybe a 2" body after a 2-4" suspension if im not happy with the height) for a total of 4-6". my question is to all of you with lift kits at what point do you notice a change in handling (i know this isnt a agile sports car that handles like none other) and how severe it is at the diffrent heights. also would i be better off with 1 kit over the other as far as what parts are included to get the height. im willing to spend more money on a better kit that "works" with everything better then a cheaper kit that will lead to parts failure due to poor geometry/craftsmanship. if anyone can give me some advice id appreciate it. id rather get your opinons because you have them on your truck and you know what works good. i have also thought about lowering it but i dont knwo if i can bring myself to lowering a 4x4 its like wipeing before you poop id just dont make sense.
Old Mar 27, 2008 | 12:12 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: lift kit/handling ability
okay, a 4 inch susp. kit doesnt exist for your truck. A 6 inch is gonna make your truck rediculously top heavy as will a 2+2...... A 2 inch susp. lift wont be so bad because it retains many stock ride characteristics and actually stiffens your front suspension causing you to corner much flatter. Wait a bit and I'm sure some guys with lifts will give youa more personal point of view for a lifted DD..
Old Mar 27, 2008 | 06:27 AM
WolfPack's Avatar
I've got the 2' suspension lift, driveway version (shackles and torsion bar lift) for $60 bucks and a socket set, not the production Rough Country or Superlift 2' kits. I've noticed the definite increase in front stiffness, but I like it much better..I was getting alot more sway and roll than I wanted to, and now it's quite a nice ride. The only problem is the main exit I get off coming home from work/the parents house is a 25 mph advised exit ramp. I used to be able to take it 30ish with no problem, but after the 2' up, 30 throws me a bit more (usually it's the back end feeling like it's wanting to roll) so I usually take it at 25 to be comfortable.
An important thing to note is that with a lift, usually one would also upgrade rims/tires. This could give you a wider stance which adds stability to account for the lift! I've always wondered about the stability of the 6ers though..hopefully one of em will pipe up!
Old Mar 27, 2008 | 07:45 AM
prozach1988's Avatar
prozach1988 is an unknown quantity at this point
im happy with how the 2 inch suspension lift is for my truck the isnt that bad but it aint no cadilac
Old Mar 27, 2008 | 11:01 AM
95LS's Avatar
if i wanted to go with 4" lift could i go with a 2" suspension and 2" body ? i just dont see how 2" suspension alone would benifit.
Old Mar 27, 2008 | 11:03 AM
WolfPack's Avatar
You'd be suprised. It went up enough I can't just step in, I have to boost up a bit..also my dog realized she now needs to jump from the ground to get in, no more front paws up first then hop the back legs up
But I want 4' too...2' is enough to make you see the light...then you just want more
Old Mar 27, 2008 | 12:34 PM
a_tack's Avatar
the 2+2 I mentioned is what people call a 2 inch suspension lift and 2 inch body lift.
Old Mar 28, 2008 | 01:42 AM
95LS's Avatar
it sucks that i have to go with a 2 or a 6 with no in between. i imagine that these companies are very simmilar in how they get their lift as far as what parts are included but i read the post about what kits do with the geometry of the rest of the suspension/driveline. you would think someone would address these issues in their kits. i honestly havent started to research any kits because i want to hear from what you guys have and how diffremtly your trucks handle after the install.
ericthughes
Lifting Tech
Oct 13, 2010 10:56 PM
Blazer man1998
Jul 2, 2008 08:40 PM
lionel2
31
Mar 14, 2008 09:58 PM
hls811
Jan 17, 2008 10:40 PM
Jimmy SS
Oct 4, 2006 03:22 AM
