Suspension Tech Have a question about modifying your suspension? Ask it here.
body lift
Old 12-04-2007, 03:12 AM
felonyblazer96's Avatar
Banned
felonyblazer96 is an unknown quantity at this point
Default body lift
ive been dying to get a lift kit but i always see them for like 500-1000 but on ebay i found a body lift kit for 114 dollars...can any1 tell me why its so cheap? is it hard to do it yourself??? please help because im very interested in getting a lift so i can fit 31 inch tires or bigger if possible thank you and any feedback is appreciated..also if you have ideas or any other advice im open to it
[/align]
Old 12-04-2007, 02:09 PM
YepIOwnA97Blazer's Avatar
YepIOwnA97Blazer is an unknown quantity at this point
Default RE: body lift
the $400+ kits are suspension lifts. Kits for $150 - $250 (depending on the year of your blazer) are most likely body lifts.
Old 12-04-2007, 03:00 PM
Banned
so the 114 dollar kit is good??? so if i get that lift can i put bigger tires on??
[/align]
Old 12-04-2007, 03:27 PM
Banned
anyone
[/align]
Old 12-04-2007, 04:30 PM
Just make sure the $114 kit is for your year and actually a BL. Make sure the kit is complete with front bumper raising brackets also. $114 isn't really that much. Synergy Offroad sells a BL kit for your year for $125.
Old 12-04-2007, 04:57 PM
972DRBLAZER's Avatar
972DRBLAZER is an unknown quantity at this point
a body lift isnt that bad to do. just get a couple friends over and it wont take that long. you are doing just what it sounds like, lifting the body. and yes you will be able to run a slightly larger tire. a good kit will come with detailed instructions. good luckwith the lift.
Old 12-04-2007, 05:29 PM
Banned
i appreciate it, so if i go with 4 inches of lift it will sit higher....i will be able to put bigger tires on.....and it will look sweet?
[/align]
Old 12-04-2007, 06:16 PM
with a body lift you are only going to get 2", but you should be able to run 31x10.5x15's on stock rims.. if they rub you could just tweak your t-bars .5" or so and they should fit without rubbing.
Old 12-04-2007, 06:28 PM
cliro's Avatar
cliro is an unknown quantity at this point
you can get a 3" body lift.
Old 12-04-2007, 06:30 PM
Banned
so the 3 inch body lift would be able to fit what size tires??????
[/align]
Quick Reply: body lift
