Suspension Tech Have a question about modifying your suspension? Ask it here.
extreame suspention
Old Jul 9, 2005 | 12:00 AM
dieselfumes's Avatar
dieselfumes is an unknown quantity at this point
Default extreame suspention
Hey i got coil springs off a 2003 s10 extreme and put them on my 2000 blazer and there is not a hight diffrence. Is there one at all or does the body kit and the diffrent rims and tires make it look at sit a lil lower????
Old Jul 9, 2005 | 02:23 AM
blazin97's Avatar
blazin97 is on a distinguished road
Default RE: extreame suspention
it is 2 or 3 inches lower. I think it is the spindles that lower it.
chris
Old Jul 9, 2005 | 02:45 AM
chevylane2003's Avatar
chevylane2003 is an unknown quantity at this point
I has 2 inch drop coils and a 1 inch drop spindle. Be sure the coils are all the way in the mounts.
Old Jul 9, 2005 | 05:59 PM
can i swap the spindles????its a diffrent set up, mine on my 2000 are sealed and everything no dust cap or anything, just 3 bolts holding the hub onto the spindle. But the spindle and hub i got off the 2003 have the dust cover with non sealed bearing and a completly diffrent rotor, well the rotor looks diffrent, not sure if it is thicker or anything. Is it ok to switch it over???
Old Jul 9, 2005 | 06:04 PM
i will post come pictures of it in a little bit
Old Jul 9, 2005 | 08:53 PM
here are the ones that r on my truck now
Old Jul 10, 2005 | 01:24 AM
here is what i want to put on it, note they r off of a 2003 s10 pick up and i have a 2000 s10 blazer, but i dont think that it makes a diffrence
Old Aug 4, 2005 | 04:51 PM
You would have to use EVERYTHING from the 2003. Just make sure that the brake line is the same style (which I think it is). The area where you are probably going to run into issues is if they changed the front wheel speed sensor design between '00 & '03. If they did, then you are in for some fun! If not, you should be able to use the control arms out. Check to make sure that the control arms line up properly and start throwing it together.
blazertim20
Lifting Tech
Dec 16, 2009 05:30 AM
boardmeblazer
Oct 17, 2009 10:22 AM
jessesjimmy
Suspension Tech
Mar 3, 2007 03:14 PM
quontush
Suspension Tech
Dec 16, 2005 06:21 PM
dieselfumes
Jun 23, 2005 06:21 PM
