front suspention/steering problem
Old Oct 14, 2009 | 03:51 PM
boardmeblazer's Avatar
boardmeblazer is on a distinguished road
Default front suspention/steering problem
Hi, I have a '98 Blazer S-10 with 165000 miles on it and knowing that at that kind of mileage in this truck things are bound to go wrong. Right now the main problem is almost like a humming noise coming from the front drivers side area but only at speeds of 30mph and less.
I looked around by the wheel and noticed that something is rubbing on the outer edge of the rim and is eating away at my wheel weight. Both the inner and outer edges of the tire is starting to crack. Any suggestions on what this might be?
thanks
Old Oct 14, 2009 | 03:53 PM
papacope's Avatar
turn your wheels to full lock and see if they are hiting anything. Does it only hum when your wheels are turned or all the timne?
Old Oct 14, 2009 | 09:34 PM
Well its all the time and it cant be the wheel bearings because i just changed the hub asem. a couple months ago. I looked under there and it looks like the bushings for the sway bar are out of place would that have something to do with it? Also i dont think that the shocks have ever been replaced.
Old Oct 15, 2009 | 12:40 AM
BlaziNator's Avatar
BlaziNator is on a distinguished road
check for clearance on the ball joints. Apparently the idiot...I mean...previous owner of my truck put a 2wd ball joint on my truck and the grease fitting on it was rubbing against the rim. Just a thought.
Old Oct 15, 2009 | 02:43 PM
papacope's Avatar
the noise could also be comeing fron a bad cv shaft. check the boots on your cvs and see if the have any cracks or tears in them.
Old Oct 17, 2009 | 10:22 AM
Alright thanks for the replies! I just figured out it could be alot of different problems
ken tweedy
Feb 4, 2010 06:20 AM
blazertim20
Lifting Tech
Dec 16, 2009 05:30 AM
jessesjimmy
Suspension Tech
Mar 3, 2007 03:14 PM
quontush
Suspension Tech
Dec 16, 2005 06:21 PM
dieselfumes
Suspension Tech
Aug 4, 2005 04:51 PM
