Suspension Tech Have a question about modifying your suspension? Ask it here.
Help Finding a 6'' superlift in canada?
Old Oct 29, 2015 | 10:21 PM
robsteez's Avatar
robsteez is on a distinguished road
Default Help Finding a 6'' superlift in canada?
Does anyone know where I can order in a 6'' superlift in canada without getting raped with extra charges and shipping? the cheapest possible way i've found is to order from the states on ebay and after a 250$ shipping fee and everything set and done will be around $2300 and its only a $1299.99 lift american...thanks!
Old Oct 29, 2015 | 11:15 PM
Blazer_4x4's Avatar
Blazer_4x4 is on a distinguished road
Amazon.com: Rough Country - 243.20 - 6-inch Suspension Lift Kit w/ Premium N2.0 Shocks: Automotive Amazon.com: Rough Country - 243.20 - 6-inch Suspension Lift Kit w/ Premium N2.0 Shocks: Automotive
Rough Country Suspension Systems Special Shipping Information
Special Shipping Information : Rough Country - 243.20 - 6-inch Suspension Lift Kit w/ Premium N2.0 Shocks
Total Shipping Cost for This Item Standard Canada $146.14
In Stock.
This item ships to Canada.
Ships from and sold by Rough Country Suspension Systems
by Rough Country Price: $1,199.95 + $146.14 shipping
In Stock.
Estimated Delivery Date: Nov. 4 - 9 when you choose Standard at checkout.
Ships from and sold by Rough Country Suspension Systems.
  • FITMENT: Chevrolet: 95-04 S10 Blazer (4-Door) 4WD, 94-03 S10 Pickup (Standard & Extended Cab) 4WD; GMC: 95-01 S15 Jimmy (4-Door) 4WD, 94-03 Sonoma (Standard & Extended Cab) 4WD
  • KIT CONTENTS: Front: Upper control arm drop brackets, upper control arm brace, front and rear crossmembers, front skid plate, lower skid plate, torsion bar drop brackets, differential drop brackets, steering link, steering stabilizer, steering stabilizer bracket, sway bar drop brackets, shock mounts, brake line brackets, and hardware; Rear: Axle perches, upper and lower u-bolt plates, u-bolts, shock brackets, brake line brackets, and hardware; Shocks: (4) Premium N2.0 Shocks
  • BENEFITS: Increased ground clearance; Laser CNC precision parts; Maintains factory geometry and optimum component angles; Front skid plate is made from HD 3/16-inch grade 50 plate steel; Features application valved N2.0 series shock absorbers which offer the best in balanced performance for on and off-road use
  • TECHNICAL NOTES: Does not fit ZR2/Highrider models, 2-Door Blazer/Jimmy models, or 4-Door S10/S15 models; Requires cutting and drilling; Requires exhaust modification; Requires rear axle flip
  • ITEM SPECIFICS: Installation Time: 8-10 (hours); Wheel Backspacing: 4.5-5 (inches); Recommended Tire Size: 265/75 R16; Total Weight: 174 (lbs)
See more product details See more product details
Old Oct 30, 2015 | 10:59 AM
El_Beautor's Avatar
I believe Interior Offroad stocked it at one point. I have no idea if they still do though. You could also check with North Shore Off Road to see if they carry it. They specialize in Jeep stuff, but they do carry lift kits and accessories for other vehicles too. Both of those ship from BC.
Old Nov 1, 2015 | 11:25 PM
robsteez's Avatar
Thanks, I forgot to note that it is for a zr2 blazer so the RC lift won't work. Also if I order from Amazon they won't ship to my adress or my buddys witch sucks. I'll call up northshore tomorrow and see if they carry it or not. The struggle living in Canada sometimes....
redfan13
Lifting Tech
Mar 2, 2009 11:11 PM
NVANZEE
Lifting Tech
May 14, 2008 06:51 AM
Cmatt1605
Suspension Tech
May 2, 2008 06:53 PM
lennyblazer
24
Jul 17, 2007 10:55 AM
jagblazer01
Suspension Tech
Nov 22, 2006 08:12 PM
