Suspension Tech Have a question about modifying your suspension? Ask it here.
leafs
Old Aug 19, 2008 | 10:56 PM
djdrew010's Avatar
djdrew010 is an unknown quantity at this point
Default leafs
My ride is rocking and I was wondering if I put and add-a-leaf in it would make the ride more stiff? I'm not looking to spend a lot being a full time student and working part-time. If this wont work what will?
Old Aug 20, 2008 | 12:12 AM
WolfPack's Avatar
Default RE: leafs
Crank your Tbars up a little bit. Less than an inch. It won't put an incredible amount of wear on the front parts, but it stiffens the ride up VERY nicely.
Old Aug 20, 2008 | 06:01 AM
Default RE: leafs
Add-a-leafs in the back would make the back end more stiff, but if it is floating around, then you probably should look into new shocks.
Old Aug 20, 2008 | 02:21 PM
djdrew010's Avatar
Default RE: leafs
replaced the shocks with reflex's at about 155000, it has like 166000 on it right now. i did the t-bar crank and it helped for a little bit but then it slowly started to loose the stiffness. I might just have a find the money for new t-bars and leafs. I'm looking a a cheap fix for the time being until I get the funds.
Old Sep 1, 2008 | 10:43 AM
El_Beautor's Avatar
Default RE: leafs
I put the long add-a-leaf in the back and am really happy with it. It stiffened up the ride really nice, and lifted the back end a little more than 2 inches. Then with a minor t-bar crank to bring my front end up a bit I'm really happy with how it rides now. I also have recently replaced shocks.
rickyp3278
Suspension Tech
Mar 26, 2008 11:03 PM
rickyp3278
Mar 20, 2008 11:38 PM
Blindthieves
Lifting Tech
Jul 25, 2007 01:41 AM
96_5spd_4x4
Suspension Tech
Apr 16, 2007 06:26 PM
Blindthieves
Suspension Tech
Mar 6, 2007 12:41 AM
