Suspension Tech Have a question about modifying your suspension? Ask it here.
Rear Shackles or add a leafs?
Old Mar 26, 2008 | 05:08 PM
rickyp3278's Avatar
rickyp3278 is an unknown quantity at this point
Default Rear Shackles or add a leafs?
2002 4wd LS Blazer...looking to cure the rear sag...add-a-leafs or shackles? What would be easier for me to do in my driveway? Let me know.
Rick
Old Mar 26, 2008 | 05:34 PM
Dturner14's Avatar
Dturner14 is an unknown quantity at this point
Default RE: Rear Shackles or add a leafs?
I guess thats all what you are looking for? The add-a-leaf will lift the rear plus give it a stiffer suspention, and the shackles with lift it and keep the same stock ride in the rear. So its up to you.
Old Mar 26, 2008 | 07:44 PM
rickyp3278's Avatar
Cool...but which would be an easier driveway job...I'm limited on tools. I mean, I have more than a hammer and a monkey wrench...just curious to see what would be easiest for me.
Rick
Old Mar 26, 2008 | 11:03 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
shackles will be an easier driveway job as you dont have to completely remove the spring. Just detach one end and swap shackles. With add-a-leaf, you have to remove the spring and add one more leaf to the stack. .
Gator Blazer
Suspension Tech
Mar 17, 2014 02:17 AM
moto x
Oct 19, 2010 04:19 PM
Benedict1337
Lifting Tech
Sep 11, 2010 10:29 PM
rickyp3278
Mar 20, 2008 11:38 PM
Blindthieves
Lifting Tech
Jul 25, 2007 01:41 AM
