Suspension Tech Have a question about modifying your suspension? Ask it here.
Lifting Back to Stock
Old Mar 30, 2010 | 08:59 PM
mhsteele's Avatar
mhsteele is on a distinguished road
Default Lifting Back to Stock
I own a 2000 2dr 2wd blazer, this is my first car, the owner befor me lowered it 2 inches and i need help returning to stock.
THE REAR: 2 inch blocks i think all i have to do is losen the U bolt and jack the axle off the block then remove the block and then tightin it back up. if im wrong please tell me.
THE FRONT: the owner befor me installed a after market part to lower it. my problem is i dont know what its called it had a inner circle with 3 arms sticking out and at the end of the arms there are holes for bolts.
I have pictures of all thease things but dont know how to attach them
Old Mar 30, 2010 | 09:04 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
correct, by removing the rear block it will raise the vehicle to stock, and the item you are talking about up front is called the spindle.
Old Mar 30, 2010 | 09:07 PM
mhsteele's Avatar
will it be easy forto replace the stock spindle. i know very little about suspention stuff
Old Jun 14, 2010 | 03:41 PM
MTopper's Avatar
it shouldn't be too hard but when you do take replace it to stock let me know how much you want for the spindles. i'm looking to drop mine and spindles are the best way to do it. (IMO)
You just need to buy a stock spindle which i'm not sure how much it would cost. you could probably junk yard it
hoebob69
Sep 4, 2014 08:57 PM
Mike98Blazer
Dec 2, 2011 12:34 AM
pmzusmc
Apr 16, 2011 09:48 AM
ChevyBlazerChick
Oct 6, 2010 10:48 PM
mhollis
Tires and Wheels
Jul 26, 2009 08:41 AM
