Suspension Tech Have a question about modifying your suspension? Ask it here.
lower control arm
Old Apr 22, 2005 | 07:37 PM
satch's Avatar
satch is an unknown quantity at this point
Default lower control arm
I have a 1999 S-10 Blazer. I have a nasty squeak coming from my front passenger side lower control arm. It is the bushing located at the front most.
From what I see the lower ball joint, shock, tie rod end, need to come off. Will I be able to get to the bushing with-out messing around with the tortion bar?
Jamie
Old Apr 22, 2005 | 11:21 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: lower control arm
if you're taking the control arm out, then yeah you have to take the torsion bar off first.
Old Apr 24, 2005 | 08:45 PM
satch's Avatar
Do the control arm bushing need pressed in/out? My thoughts are if only remove said componets(see first post) and NOT the torsion bar, that I might be able to get just enough access to the front bushing on the control arm.
Old Apr 24, 2005 | 10:06 PM
zero psi's Avatar
Retired Admin
theres going to be so much tension on that control arm, that you wont be able to move it anywhere. the torsion bars are real simple to take out. they have a tool to make it a breeze.
latinoNJ
Sep 7, 2010 07:25 PM
Beckyj636
Jul 13, 2010 03:16 PM
PaulO2288
Mar 13, 2010 09:01 PM
whitejimmy
Feb 19, 2010 09:51 PM
Major Pain
Suspension Tech
Dec 17, 2005 08:37 PM
