Ls-zr2
I have a '98 Blazer LS Vortec V6 with the stock suspension. I really want to put a ZR2 suspension on it but I'm not sure where to go to get this done as far as purchasing goes. Any help is appreciated. If I can get some pricing too that would be awesome.
hey buddy zr2s have bilstein shocks different leafs and a wider stance also skid plates and alot of the other parts have to be different also because you have to order parts zr2 specific overall they set 2inches higher and wider and they also have a lower geared diffs 3:83s instead of 3:73s
as zr2 dan said well more in a nut shell is that zr2 parts wont fit on an ls also take it from me (i tryed to put zr2 parts on my ls) the frames are different not only are the wider but also stuff like the a-arm tabs are different and the leafs are longer then the ones in the ls
Short answer is no you cant do this.. but if you really wanted to spend alot of money and have all the mods done to your frame could be done, but not at all worth it. i asked this question a while ago and and the answer i got is that the way the ZR2 suspension mounts up to the frame is completely different than a regular blazer. i thought the only parts you could take from a ZR2 and put on a normal blazer without mods where the leafs but according to jacked up that would be wrong and he is probably right.
If your trying to be more like a zr2, goto the yard and find a zr2 and get the axle's off, fender flares, and then buy either a body lift or suspension lift. That'll get your wider and taller stance. Just my .02.
i m not sure where u are but i just finished swaping my frame and running gear out for theZR2 set 3.73 gear from 3.42 stearing stab bigger sway bar 4 wheele disc brakes dule piston calipers ,ther is some work involved but worth it i got the frame from s10 depot in sarasota fl great people i have a stocl 97 frame with a 5 inch lift installed for sale CHEEP!
Hey fellers, I have a question... I found a rolling chassis of a ZR2, will my engine, tranny/transfer case, body and everything else bolt right up to it? heres the kicker.. i have a 97 LS blazer, this ZR2 blazer chassis is a 99. i'd hate to throw $500 in the trash and rip my ride apart for nothing!
