Suspension Tech Have a question about modifying your suspension? Ask it here.
Ls-zr2
Old Dec 18, 2012 | 07:19 PM
El_Beautor's Avatar
If all you'd be using is the frame and suspension then it might work, but it's a whole ton of work to swap your drive train and body over, just for 2 inches of lift, and a bit wider? why not just lift your truck as is, pull the fender flares, or even the front fenders complete and go from there? It would be a ton easier for the same price.
Old Dec 21, 2012 | 04:03 PM
SoullessNihilist's Avatar
SoullessNihilist is on a distinguished road
I already have a body lift, 1.5in lift shakles with torsion tweak, front fenders and rear flares off a ZR2, mounted a spare tire rack and put 31's on it. the point of the swap is for a little more lift to fit 33/10.5/15's, a tougher frame and suspension, two more inches of width and 3.73 gears instead of 3.42... plus i feel like a fraud! i want the real deal haha
Old Dec 21, 2012 | 10:28 PM
blaz's Avatar
blaz is on a distinguished road
Here is my LS with 33x10.5's with only a 2" bodylift and a 1.5" tbar crank. I have since added a 2.5" RC lift.
A ZR2 will be easier but just buy one and mod it after selling yours. Way less work.
Old Dec 22, 2012 | 01:35 PM
where those tires rubbing Blaz? looks like you cut the front bumper in half?
Old Dec 23, 2012 | 12:23 AM
blaz's Avatar
Yes the tires did rub slightly when the tires were turned at a certain angle and the steering stops were built up to prevent frame rub. There was zero rubbing when on the street, but as you can tell the blazer does get used off road.
As for the bumper, yes it was cut in half and a winch mount was made for the center. I then trimmed and re attached the sides of the factory bumper.
Bberry20
Feb 25, 2010 09:28 PM
Spectreblazer
Feb 13, 2010 04:59 PM
Logan
36
Dec 6, 2009 07:41 PM
PJT2007
Oct 7, 2008 10:47 PM
Logan
Lifting Tech
Sep 18, 2008 11:44 AM
