Suspension Tech Have a question about modifying your suspension? Ask it here.
Need Help Lowering
Old Dec 2, 2004 | 09:48 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: Need Help Lowering
im not sure, but i think it was just basic tools. i can't think of any specialty tools needed to do the job. just wrenches, hammer, sockets, allen wrench (i think a 3/8), jack, and stands. a torque wrench would probably be a good idea too. and some wheel bearing grease. thats all i can think of, i did it so long ago, so i might be forgeting something, but i remember it was really easy. just take your time and double check everything when you are done.
Old Dec 3, 2004 | 04:10 AM
01xtreme's Avatar
01xtreme is an unknown quantity at this point
Don't forget to bleed the brakes!
Old Dec 3, 2004 | 09:24 PM
Blaize70's Avatar
Blaize70 is an unknown quantity at this point
ok so do they come with directions like the spindles and blocks or do i have to look that up on line. Thanks for the input
Old Dec 4, 2004 | 12:22 AM
zero psi's Avatar
Retired Admin
ORIGINAL: 01xtreme
you don't have to if you don't disconnect the brake line. just unbolt the calipers and use some mechanics wire to tie them up out of the way so they don't dangle by the lines.
Old Dec 4, 2004 | 04:54 AM
01xtreme's Avatar
I used to work at a lube/oil shop and everytime we turned the rotors and changed pads, we bled the brakes. Maybe we never had to but we just did it as an extra precaution. I'm just going by the experience that I've had.
Old Dec 4, 2004 | 12:11 PM
zero psi's Avatar
Retired Admin
yeah, you're right. might as well while you're there.
Old Dec 6, 2004 | 02:10 PM
Blaize70's Avatar
man u guys r genius's. Ok so again i am totally truck retarded so how do i bleed the brakes?
Magnum099
Lowering Tech
Jul 6, 2014 12:09 AM
izzyb1986
Lowering Tech
Jul 3, 2010 08:39 PM
izzyb1986
Lowering Tech
Jun 29, 2010 01:25 AM
lsv93delsol
Lowering Tech
Oct 13, 2009 09:59 AM
speeddemon560
Suspension Tech
Feb 6, 2007 04:18 PM
