Suspension Tech Have a question about modifying your suspension? Ask it here.
NEED SERIOUS ADVICE !!! LIFT, SHOCKS ??
Old Sep 12, 2006 | 08:42 PM
tommyd's Avatar
tommyd is an unknown quantity at this point
Default RE: NEED SERIOUS ADVICE !!! LIFT, SHOCKS ??
Thats the point of the new UCAs is to correct the ball joint problem the rough countrys had. Now they seem to come with new UCAs so the problem should be fixed. I don't have any proof of them actually working but my guess is they are superlift UCAs or a copy of them. Either way it should be corrected.
Old Sep 12, 2006 | 08:50 PM
ceanern's Avatar
ceanern is an unknown quantity at this point
Thanks for giving me the explaination.
Old Sep 12, 2006 | 09:03 PM
offroadin00blazer's Avatar
offroadin00blazer is an unknown quantity at this point
thanks guys i think im going to save up and go for the 5 in lift. !!!!
Old Sep 12, 2006 | 11:05 PM
ok, i was talking to dad about how the 2 in lift can possibly cause damage to other parts and he said that i should just upgrade the shocks and if i really want to be higher just get a 3 in body lift cause if i save up for the 5 in im going to have to get bigger tires and wheels and i just got new tires so i really dont want to have to do that, so now that im not going to spend money for a lift what shocks out there are the best out there?
Old Sep 13, 2006 | 02:31 AM
tommyd's Avatar
Bilstein(sp?) makes some of the best all around shocks out there. I have also heard good things about the dual tube edelbrock IAS shocks. Rancho also makes good shocks. I wouldn't both body lifting it. The only readon you body lift is to clear bigger tires the cheap way. If you arn't going to put bigger tires on it there really isn't a point to doing a body lift right now. It just causes clearance issues (from what I hear) with the fan and the shroud. Plus the frame will show like crazy and the tires you have now fit the way the vehicle sits now. A body lift won't gain you any extra ground clearance.
Old Sep 13, 2006 | 09:34 PM
good point. i was talking to a friend a couple days ago and he told me that i should be able to put a chevy s-10 lift on it. is this true?
bigdaddykane93
14
May 8, 2014 08:54 AM
Doverman454
Aug 14, 2010 11:46 PM
whitejimmy
Lifting Tech
22
Mar 8, 2010 02:50 PM
jagblazer01
Apr 16, 2009 03:54 PM
strykerthat
Suspension Tech
Oct 9, 2007 06:57 PM
