Suspension Tech Have a question about modifying your suspension? Ask it here.
revolver shackles
Old Jan 23, 2009 | 12:54 PM
sapper7delta's Avatar
sapper7delta is an unknown quantity at this point
Default revolver shackles
im trying to find were i can purchase revolver shackles for my 1975 blazer. i have seached all over and can only find them for jeeps and small vehicles. if anyone knows of a one of these other vehicles that they make them for that might fit my application please let me know thanks
Old Jan 23, 2009 | 01:01 PM
Default RE: revolver shackles
What do you mean by revolver shackles? Are you talking about a shackle flip? Front or rear?
Old Jan 23, 2009 | 02:28 PM
WolfPack's Avatar
Revolver shackles are hinged shackles that when under load are folded up, and the same size as a normal shackle. When flexing, the shackle opens up, allowing much greater flex. Theyre supposedly designed for the vehicle to prevent driveline binding...but..Ive heard mixed reviews.
I dont think I've seen them for K5s...Just s10 blazers/trucks Revolver Shackles
Old Jan 23, 2009 | 06:53 PM
Brain fart! LMAO!!
Yep, thats what they are. As far as finding them for the K5. The problem you will run into in the back is that the stock rear shackle hanger is inverted (ie. under the leaf spring). You would need to do a shackle flip in the back before doing this arrangement. That will lift the rear 4" with most typical shackle flips.
In the front, the shackle goes through the center of the frame where it is dropping down to go under the cab. Also, the shackle for the front is in the back of the spring which would not make for a favorable situation with your front pinion angle using a revolver. So the front suspension would have to be modified with a fixed mount for the rear of the front spring and the shackle up front.
jdespain
Lifting Tech
14
Jan 29, 2010 10:07 AM
dirtydave
Suspension Tech
Dec 18, 2009 04:21 PM
moose4553478
Lifting Tech
Oct 24, 2009 12:41 AM
Blindthieves
Suspension Tech
Mar 6, 2007 12:41 AM
jimmyboy
Tires and Wheels
Dec 4, 2006 09:46 PM
