Suspension Tech Have a question about modifying your suspension? Ask it here.
SOA lift?
Old Sep 16, 2006 | 05:04 PM
richlo's Avatar
richlo is an unknown quantity at this point
Default SOA lift?
hi, i am new to the blazer world, but i just acquired a 2001 Blazer ZX2 2-door a little while ago. However, i am familiar with jeeps, and a very popular lift with them is the Spring Over Axle lift... its pretty self explanitory, you take an axle that was on top of the spring, and move it to the bottom of the spring. i was just wondering if you can do this with the rear axle of a 01 blazer? also, what can i do to get this more off-road ready (can i remove trac bars, sway bars, etc to get more articulation while still remaining street-able)?
Old Sep 16, 2006 | 06:04 PM
sledneck16's Avatar
sledneck16 is an unknown quantity at this point
Default RE: SOA lift?
if you really want a decent on road and very capable off road blazer definetly go with a SOA out back, and you have 2 options out front--and 5' lift (superlift is nice) but if you wanna ditch the traction bars you should go with a solid front axle swap as well with a SOA on that........
theres really not that much to choose from with our trucks---but what there is out there is great!
Old Sep 16, 2006 | 07:03 PM
richlo's Avatar
so there wount be any driveshaft/u-joint issues with the increased angle? and for the istallation all that has to be done is re-weld the spring mounts from the bottom of the axle to the top?
Old Sep 16, 2006 | 10:33 PM
sledneck16's Avatar
im 99% sure you'll be fine angle wise out back----I personally haven't done a SOA so im not sure---anyone?
Old Sep 17, 2006 | 03:18 AM
ceanern's Avatar
ceanern is an unknown quantity at this point
not sure but listening... Was thinking of doing the same thing with my blaze. But just gotta have the time to do so.
Old Oct 21, 2006 | 08:11 PM
richlo's Avatar
anyone? any help is much appreciated.
Old Oct 28, 2006 | 06:30 PM
Cow Killer's Avatar
Cow Killer is an unknown quantity at this point
go to www.zr2usa.com they will help you out more. only zr2 owners are alowed. they wouldnt let me.
i would say the rear angles will be steep, probly wont be able to use stock rear shaft.
johnnymurad
Lifting Tech
Jan 29, 2012 01:02 PM
Sean Braswell
Lifting Tech
Apr 28, 2011 03:54 PM
Steinbruchsoldat
Lifting Tech
Feb 3, 2011 05:55 PM
NVANZEE
Lifting Tech
May 14, 2008 07:57 PM
NVANZEE
Feb 26, 2008 05:04 PM
