Suspension Tech Have a question about modifying your suspension? Ask it here.
steering hard cont'd
Old Jan 11, 2007 | 01:01 AM
blazinfast's Avatar
blazinfast is an unknown quantity at this point
Default steering hard cont'd
i posted a while back about some possible clues as to what might cause some lowspeed hard steering.
i thought it might be my power steering pump going bad, but just recently i went to get brakes and an alignment and the guy told me i had a busted ball joint
that wouldnt cause my power steering to get hard at lowspeeds would it?
Old Jan 11, 2007 | 01:03 AM
4lowlife's Avatar
Default RE: steering hard cont'd
is the pump making noise even at idle?
Old Jan 11, 2007 | 01:06 AM
blazinfast's Avatar
no it doesnt make noise evre, it just is really hard to turn unless i give it gas or im going over 20
Old Jan 11, 2007 | 01:08 AM
blazinfast's Avatar
oh yea, its a k-5, one of the old blazers
1985
Old Jan 12, 2007 | 12:23 AM
blazinfast's Avatar
nobody?
Old Jan 15, 2007 | 11:01 PM
drperry's Avatar
Is the power steering fluid level good?
Old Jan 18, 2007 | 09:55 AM
blazinloud's Avatar
does it use the rackinpinion(sp) steering? sounds like the same thing that happend to my Z24.
said i needed a new rack........I'd talk to chevylover, he has a whole family of K5's
Old Jan 18, 2007 | 10:13 AM
Nope, it would be the old reciprocating ball steering box. And to answer the original question, I don't think that a worn ball joint would make slow speed turning more difficult, although you will want to get it changed ASAP. Well, that is if you like keeping that wheel in place...
It is possible that your pump is worn and requires more RPMs to assist in the steering at slow speeds.
As mentioned earlier, is the fluid in the res up to the proper level? If it is, then it is quite possible that you need a new pump.
Old Jan 18, 2007 | 06:38 PM
drperry's Avatar
My ol' Mazda was almost the same... sometimes at less than 1500 RPM, the power steering would work in reverse... made it harder to turn, than if it would just stop assisting.... rev the snot out of it and it went back to normal...
Old Jan 21, 2007 | 02:11 AM
blazinfast's Avatar
yea the power steering fliud is good and at the proper level, so i guess it must be the pump, i wsa afraid that would happen
TZFBird
Apr 11, 2014 01:31 PM
jackdough
Jun 18, 2009 06:42 PM
Litman15
Apr 19, 2009 07:23 PM
blazinloud
Feb 16, 2006 08:00 PM
