Suspension Tech Have a question about modifying your suspension? Ask it here.
Superlift kit...welding??
Old Apr 20, 2008 | 06:11 PM
Cmatt1605's Avatar
Cmatt1605 is an unknown quantity at this point
Default Superlift kit...welding??
okay, so i have a 1997 blazer, bone stock, and i have no access to a welder, i was wondering from you guys who have put these on, how much welding is involved, if any?
[IMG]local://upfiles/10555/45FBD05104DE4A95942A5F4BAD1FEB64.jpg[/IMG]
[IMG]local://upfiles/10555/B9D3B05B64544540AAD09725AB1772F6.jpg[/IMG]
Old Apr 20, 2008 | 06:40 PM
nj4x4blaze's Avatar
Default RE: Superlift kit...welding??
There some welding and alot of cutting involved. It's not an easy kit install. My install was a PITA.
Old Apr 21, 2008 | 03:18 PM
Cmatt1605's Avatar
oh okay, any cutting or replaceing is fine, im pretty good with cars and trucks, just welding isnt my strong point, i saw a cheap welder at owes, just 2 tanks and a torch, would that work?
Old Apr 21, 2008 | 03:59 PM
Cmatt1605's Avatar
Old Apr 21, 2008 | 04:59 PM
nj4x4blaze's Avatar
My boy used a tick welder on mine. Not sure how well a torch welder would work. You might wanna give the guys at Superlifts a call regarding installation techniques. I've called them before with questions and they were very helpful throughout my install.
Old Apr 27, 2008 | 10:54 AM
GeorgesBlazah's Avatar
GeorgesBlazah is an unknown quantity at this point
You haveto weld the rear spring perchs on and you need to weld a support in on the front of the frame. I think any welder would do, just make sure you do them.
Old May 2, 2008 | 06:53 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
I have one thing to say about welding... this comes from 4 generations of miilwrights.... A good weld is not hard to make. A good looking weld is.
Strong durable welds are not difficult to do, now making it look good is the hard part. If you dont care about the look of the weld then you should have no problems..
ckroll98
Mar 31, 2021 12:12 PM
Davidhicks80
Lifting Tech
Jul 30, 2012 10:00 PM
leeclark
Mar 25, 2012 06:32 PM
Mr.T
Jul 31, 2010 07:19 AM
LowLife
May 13, 2010 10:06 AM
