Suspension Tech Have a question about modifying your suspension? Ask it here.
Suspension Upgrade
Old Aug 4, 2009 | 10:51 PM
SymClone's Avatar
SymClone is on a distinguished road
Default Suspension Upgrade
I have a 2003 Chevy Blazer LS 2 door with 4.3 Vortec and I have decided to start upgrading the suspension. I want to achieve a three inch lift, but i really do not want to spend the money on full suspension kit. Instead i want to purchase as couple items at a time, and over time eventually get the desired lift. I have never upgraded suspension so i have no idea where to start. I am also interested in tire input for the 15 inch stock rims on it.
Old Aug 5, 2009 | 12:56 AM
NVANZEE's Avatar
I would get a 2in body lift. The cost around $250. Then you can crank the torsion bars one inch in the front and get either shackles or an add-a-leaf for the rear. With that setup you will be able to fit 31x10.50 tires. They will rub slightly at full lock on the frame but thats no big deal. If you plan on taking off-roading they might rub the top of the fender but that depends on how hard you wheel it. Do a search and you will find everything you need to know.
Old Aug 5, 2009 | 12:57 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
i would suggest searching through the forum and gather all of the info you can so you can get a good idea of what youre going to be getting into.
Old Aug 11, 2009 | 10:49 AM
SymClone's Avatar
Thanks for the input guys!!
PawNtheSandman
Headers, Intake, & Exhaust
22
Jul 10, 2008 07:12 AM
darylfiend111
Tires and Wheels
Aug 10, 2006 12:07 PM
XBlazer01
Apr 29, 2006 04:18 PM
field@esivb.com
Apr 20, 2006 08:59 PM
ThisSideUp
Jul 18, 2005 04:51 PM
