Suspension Tech Have a question about modifying your suspension? Ask it here.
torsion bar keys or/and crank whats the diff
Old Sep 22, 2009 | 02:37 PM
Duram98jimmy4x4's Avatar
Duram98jimmy4x4 is on a distinguished road
Default torsion bar keys or/and crank whats the diff
Just curiouse I was thinking about cranking up the t-bars this weeke nd to level the jimmy off and was wondering if i had missed something. what exactly is the key used for when u purchase a lift kit? when reading how to crank the t-bars i read no mention of this is it nessesary? Why would i want the keys i may have missed something so thought it was worth asking.
Old Sep 22, 2009 | 08:00 PM
neo71665's Avatar
Cranking is free, keys just reindex the bar basically doing the same thing as a crank but costs money.
Old Sep 23, 2009 | 05:16 PM
amazinnblazin's Avatar
amazinnblazin is an unknown quantity at this point
You already have 'keys' in, the others are crap, just new ones, I have heard many times they don't even give more lift, just make you feel better about yourself lmao.
Old Nov 27, 2009 | 07:13 PM
Brianator99's Avatar
Brianator99 is an unknown quantity at this point
Yeah just lift your factory keys. 4 turns = 1 inch of lift in most cases unless your torsion bars are really worn. Don't waste your money on the keys and don't go overboard on cranking your keys.
Old Mar 18, 2011 | 09:09 PM
TMM217's Avatar
TMM217 is on a distinguished road
Default torsion bar crank vs. lift keys
Just cranking the torsion bars will not allow for as much lift and will add too much stress on the adjuster bolt when out all the way. These torsion keys have a removable cam that allows you to reposition the torsion bar with the keys which makes for more adjustment without turning the adjuster bolt to its max position.
Old Mar 19, 2011 | 07:18 PM
neo71665's Avatar
You don't want over 1.5 inches on a s-series . The ones with the cams are just overpriced and no need for them. You are putting the same amount of stress on the adjusters no matter where the bolt is threaded in, you only change the amount it needs to be threaded with the adjustable cams. You want to waste money on un-needed and overly complicated parts when its not necessary be my guest.
8five-k5
Suspension Tech
Feb 15, 2011 11:49 PM
SCHLAKER-PTZR2
Lowering Tech
Mar 5, 2010 08:16 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
tkebillybob
Jan 16, 2008 06:45 PM
