Suspension Tech Have a question about modifying your suspension? Ask it here.
Torsion Bar question.
Old Aug 13, 2010 | 02:09 PM
93BlazerSport's Avatar
93BlazerSport is on a distinguished road
Default Torsion Bar question.
Hi all. I have a 93 Full Size Blazer. When looking at the truck from the side the front-end sits higher. When I go over speed bumps too fast or hit pot holes I notice quite a lot of cluncking noise and bounce. I think that the torsion bars are cracked up because it appears the previous owner had a snow plow. Is there a chart or something to let me know what the stock setting should be on the torsion bar? I am thinking about cranking it down some to see if I can improve the ride and get the truck looking a little more level. Thank you in advance for your imputs.
Old Aug 13, 2010 | 02:12 PM
Just crank them down until the height evens out.
Old Aug 13, 2010 | 03:11 PM
Benedict1337's Avatar
I'd check the other front end parts about the clanking as well because most snow plow vehicles take a lot of abuse in the front end
Old Aug 13, 2010 | 06:44 PM
Thanks for the tips. The front is about two inches taller than the rear so I have some cranking to do. I've already inspected all of the front end parts & suspension which panned out all clear. I think the torsion bar is up too high and hence it is causing the rough ride and noise.
Old Aug 13, 2010 | 08:06 PM
did you check your cv axels they could be clanking as a result of the torsion bars being cranked to high
azzr2
Mar 25, 2012 04:19 PM
mdehoogh
Suspension Tech
Dec 3, 2008 06:51 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
KenpoFish
Feb 5, 2008 08:38 AM
stevelknievel
Lifting Tech
Apr 23, 2007 12:57 PM
