Suspension Tech Have a question about modifying your suspension? Ask it here.
U Joints
Old May 5, 2006 | 12:36 PM
Default RE: U Joints
ORIGINAL: m00nwater
ORIGINAL: 4lowlife
There will be some play in the shaft.
You said "play" and "shaft" in the same sentence[sm=icon_rofl.gif]
LOL! You beat me to it! Shaft!... HAHA!
Ok... Back on topic... m00n, you're lookin' at ~$20 each, but the listing for your '93 is weird. Does that have a 3 joint rear shaft in it?
Old May 5, 2006 | 02:30 PM
m00nwater's Avatar
m00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond repute
Good question...you know how useless I can be...what you just said was like, "Whaa, woo,waa, waaa" all Charlie Brown teacher style and all. I'll find out. I figured they would be pretty cheap. I live about 4 min drive from the NAPA, so I might just stop in there to figure it out anyway. I have to go to get a new oil drain plug (rubber's goin') and plugs & wires, so I'll figure it out. Thanks for the info that they will be around $20 though. That way I can make sure they give them to me cheaper than that with my discount.
I'm wondering if I should try and get help and do it myself or just send it to the shop. I'm a fast learner, but it might be beyond my abilities with help. I suppose I'd need a hoist anyway.
Old May 5, 2006 | 02:37 PM
No hoist necessary. Pull it into the grass (if you can, straddle a low spot in the grass so you can get underneith good and drop the driveshaft out. The whole driveshaft should come out by just removing the 4 bolts & 2 straps that hold the driveshaft to the rear axle. But I don't know how your trucks driveshaft is laid out...
You may need a vice or at the very least a large C-clamp to press out the old u-joint cups and press in the new ones. I typically use a socket that is a bit smaller on the outside than the cup on one side, and another that is alittle larger on the inside for the other and press them out. It can be done with a C-clamp, but it's MUCH easier with a vice.
Old May 5, 2006 | 03:08 PM
4lowlife's Avatar
quote:
ORIGINAL: 4lowlife
Some clunking sounds could be eminating from the door hinge pins, hood or the U joints
I have to change the front pass side door hinge pins and the same side hood washers.
Anyway.....I'm getting that "play" in the shaft, that's why I suspected it.
I'm going to price 'em out at NAPA.
_____________________________
little girl in a big truck
[sm=funnypostabove.gif]
I didn't realize I typed that!
LoLoS10Blazer87
Suspension Tech
Sep 19, 2008 07:43 PM
tom1337
17
Mar 12, 2006 10:44 PM
TDQ
Suspension Tech
Jan 9, 2006 01:50 AM
alexbtango15
Suspension Tech
Jan 7, 2006 01:06 AM
hdlogistics
Suspension Tech
Dec 2, 2005 10:53 AM
