Suspension Tech Have a question about modifying your suspension? Ask it here.
Zr2 Front Diff Swap
Old Jul 7, 2012 | 12:14 PM
I drive Chevy's Avatar
I drive Chevy is on a distinguished road
Default Zr2 Front Diff Swap
So i know its possible and ive done a ton of searching and have seen it done. With that said i just have one question, do i really only need the front diff and thats it? To me it just doesnt seem like just swapping the diff will widen the front end. I already have a zr2 rear axle and my front has 3.42 gears so i thought i might as well try widening the front while getting the right gears. Any help would be appreciated.
Old Jul 7, 2012 | 02:28 PM
warthogdriver's Avatar
first off it is very important that the front and rear diffs have the same ratios.
http://www.google.com/webhp?rlz=1C1C...w=1024&bih=677
that may help ya
Old Jul 7, 2012 | 04:02 PM
okiedoak20's Avatar
from what i have found is that all the drive train stuff is the same (except for the 8.5" rear slightly wider)its the frame and the cv axles that are longer, and it seems that the control arms are even the same
find a front diff from a manual zr2 and get the diff in iron instead of aluminum
Old Jul 7, 2012 | 05:41 PM
The front axle/differential from a ZR2 will not widen the front end of a non-Z. That is all in the frame AND suspension of the ZR2. So if that is the end goal that you are trying to attain, you will not get there by swapping the front diff from a ZR2.
Old Jul 7, 2012 | 05:52 PM
That's what I thought but I just had to make sure I wasn't crazy. My goal was to get 3.73 gears up front and hopefully widen the front. Wheel spacers it is then
Old Jul 8, 2012 | 01:03 AM
neo71665's Avatar
Get rims with the correct backspacing to widen the front.
goldnugget
Feb 25, 2022 09:56 AM
simmonsnick
Feb 5, 2011 05:50 PM
SmokeDogg
Jul 14, 2010 12:05 PM
SPEEDIE93
Aug 5, 2009 12:44 AM
Millertime21
Oct 12, 2008 03:21 PM
