03 Blazer 4x4 fitment question
Old Oct 26, 2007 | 09:10 PM
brunosrk's Avatar
brunosrk is an unknown quantity at this point
Default 03 Blazer 4x4 fitment question
I have a 03 4x4 2 dr Blazer LS. I'd like to put a set of Weld Pro Stars on it. These are the specs of the ones I'm looking at. 15x7, 5.5 inch backspace and 38.00 mm offset. I'm also thinking of running 30 inch tires. What you think?
Old Oct 28, 2007 | 01:50 PM
Hanr3's Avatar
Default RE: 03 Blazer 4x4 fitment question
sounds like a plan. Post up some pics.
Old Oct 28, 2007 | 04:57 PM
brunosrk's Avatar
So you don't think I'll have many problems with the wheels I described?
Old Oct 28, 2007 | 06:29 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
It sounds like those should work perfect, they will stick out about a half inch more than stock and then with the 30x9.5" tires you will have about a .5"-1" wider tread pattern IIRC. So it should fit in there no problems with the stock suspension setup. Otherwise you could crank the torsion bars about a half inch if you need just a litte bit more clearance. But I think the 30" tires should work fine.
wolv2401
Tires and Wheels
Mar 11, 2007 01:37 AM
wolv2401
Tires and Wheels
Feb 28, 2007 01:42 AM
drperry
Tires and Wheels
Jan 28, 2007 05:40 PM
jagblazer01
Tires and Wheels
Nov 24, 2006 01:31 AM
