20" rims on 2000 Blazer LS
Old Jan 22, 2009 | 01:20 PM
screzlose8's Avatar
screzlose8 is an unknown quantity at this point
Default 20" rims on 2000 Blazer LS
I'm new to putting new rims and tires on my blazer LS. I want to know if i can fit a 5 lug universal 20" rim on my 2000 chevy blazer LS. I dont know anything about the bolt pattern of the rims as a buddy got them and has no use for them and asked if i wanted them. The rims are made by "Vault" and they are called "Elixir" other than that the tire size is 245 40zr20.
Any help on this would be GREATLY APPRECIATED!!!!
thanks
Old Jan 22, 2009 | 02:02 PM
deadbuzzard's Avatar
deadbuzzard is an unknown quantity at this point
Default RE: 20" rims on 2000 Blazer LS
could take one and just try to put it on to see if it fits and if there is enough clearence all around the tire
Old Jan 22, 2009 | 02:32 PM
Blazin1's Avatar
Blazin1 is an unknown quantity at this point
The 20's should fit. You might have to use spacers depending on the rims though. Look forward to making wider u-turns and rubbing if you turn the wheel too much. I like the look but the ride kinda sucks.
Old Jan 22, 2009 | 02:44 PM
screzlose8's Avatar
ORIGINAL: Blazin1
Yeah ... pretty much figured that there would be rubbing....but if i put the spacers on would it take care of that problem?
Old Jan 22, 2009 | 03:20 PM
Blazin1's Avatar
It all depends on the rims, but not really. It's notreally a huge problem. I wouldn't worry about it. In my case I had to use spacers because the rims fit but wouldn't rotate in the front, so I got longer lug studs and spacers. I still have to do the rear, but inthe rearI didn't have this issue. I would throw those bad boys ON!!! [sm=smiley2.gif]
Old Jan 22, 2009 | 03:39 PM
screzlose8's Avatar
Thank you very much for the help... Try throwin these puppies on on sunday hopefully they "fit right"[&:]
Old Jan 23, 2009 | 07:55 AM
Blazin1's Avatar
No problem, glad to help out a fellow member.
Keystoneguy91
Tires and Wheels
Oct 27, 2012 09:40 PM
01Blaze218
Oct 13, 2011 10:05 AM
electricproff
Tires and Wheels
Jan 23, 2009 12:29 PM
00Blazin
Nov 13, 2008 12:09 AM
BSchorr
Tires and Wheels
Mar 23, 2008 09:17 AM
