20" rims with 33" tires...
Old Mar 17, 2008 | 05:20 AM
Audissey's Avatar
Audissey is an unknown quantity at this point
Default 20" rims with 33" tires...
these seem to be the craze out here in hawaii and i'm considering doing this to my blazer after my lift. just wondering if anyone had any recommendations or something. also, i'm looking for a site to buy wheels off of but i cant really find anything even for like 15-17" wheels for a 2000 4x4. i have searched so please dont ream me with "use the search" replys. thanks for all your help guys, i really love this site. i have learned alot.
Old Mar 17, 2008 | 06:27 AM
jimmyboy's Avatar
jimmyboy is an unknown quantity at this point
Default RE: 20" rims with 33" tires...
here is a good site for 15s-20s http://www.4wheelparts.com/CT11.aspx
jimmyboy
Old Mar 17, 2008 | 06:28 AM
nj4x4blaze's Avatar
I have a set of 20's for my truck as well and still deciding whether to run 32's or 33's on them.
Old Mar 17, 2008 | 03:39 PM
Audissey's Avatar
thanks jimmyboy
nj4x4blaze, is there something i need to know when pruchasing 20's? or does it even matter? (as far is if i'm gonna use big tires on em)
Old Mar 17, 2008 | 04:14 PM
jimmyboy's Avatar
just a heads up bolt pattern is 5x 4.75 and if you are 4x4 then its a got to have a backspacing as close to 6" as possible. the less you have the more it will make the wheel stick out causing more tire rub.
jimmyboy
Old Mar 18, 2008 | 05:57 AM
nj4x4blaze's Avatar
Well with a lifted truck you want at least a 4.5 or 5" backspace. If you use the stock back space you will run into the issue of the wheel rubbing. How wide of a wheel are you going with? Mine are 20 x 9.
Old Mar 21, 2008 | 04:03 AM
Audissey's Avatar
not sure yet as to how wide but prolly gonna be around 9-10" rim.
thanks for all the info guys.
Old Mar 21, 2008 | 11:17 PM
fla_blazer4x4's Avatar
fla_blazer4x4 is an unknown quantity at this point
yea everyones doing it to the truck here in florida 2 theres a guy with a lifted bronco with i think 22s on some mud terrians lifted looks sweet with all tha bling and shiny then looks better lifted with 35 or 33 i like 33s more then 25 cuz im more into skinny tires then fattys
[/align]
Old Mar 22, 2008 | 12:32 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
check the Superlift website and on the info for their 6" lift it gives reccomended rim specs for a blazer/s-10 lifted 5-7"
*EDIT*
Looked for ya...
Superlift.com
Non ZR2
33 x 10.50 on a 8" wheel with 5.5-6" backspacing
BDSsuspension.com
Max. Tire Size: 31" x 10.50
Max. Wheel Size: 15 x 8
Back Spacing: 5-6"
Old Mar 22, 2008 | 08:01 AM
Audissey's Avatar
thanks man. appreciate the info.
i have decided to go with these wheels on some 33's...
Blazonaire
Tires and Wheels
Oct 14, 2015 11:32 AM
Striker911
Mar 6, 2014 11:56 AM
98Ltblazer
Aug 19, 2010 07:06 PM
EuroGoldLS
Tires and Wheels
Mar 31, 2007 08:36 AM
blazerbob
Tires and Wheels
Mar 19, 2007 08:38 PM
