2002 2 Dr blazer 2 wheel drive tire size
Old Feb 13, 2008 | 09:50 AM
BlueBLazer985's Avatar
BlueBLazer985 is an unknown quantity at this point
Default 2002 2 Dr blazer 2 wheel drive tire size
What is the largest tire I can fit wthout any rubbing. My Blazer is stock. Its just a plain 2 door 2 wheel drive. It has 235/70/r15 on it now. I want bigger but don't want to lift it right now. I read alot of post about 4X4 but none about 2 wheel drives. thanks in advance for any help.
Old Feb 13, 2008 | 10:31 AM
Default RE: 2002 2 Dr blazer 2 wheel drive tire size
Asked and answered several times. Look at the sticky at the top of this section.
Old Feb 13, 2008 | 04:47 PM
Everything is for 4x4. I search the whole sit and never could find an answer.
Old Feb 13, 2008 | 05:47 PM
mdehoogh's Avatar
you should be able to fit 30x9.5x15... i dont believe the 2wd blazers sit any lower than the 4wd. my 4wd has 235/70r15 but many 2wd's came with 235/75r15 (lil taller)
i say, if you want bigger tires but dont want to lift now, wait until you absolutely need tires. 2wd's can be lifted for very little money. by lifting a few inches, you should be able to fit 31's or maybe even 32's (depending how high you lift)
Old Feb 19, 2008 | 08:33 AM
Thanks. I don't really want to lift it because I drive mostly on highway and in the city of New Orleans to work. But I want a little mor eaggressive look and the stock size tires just don't do it.Nut I go offroading at least twice a month. I know a @wd for offroading and mud riding butmy brother in law pulls me out if i get stuck. i want to make myBlazer a little better offroading so i won't get stuck as bad.
i have the z85 suspension on my blazer. Will they rub while offroading or trailering. I pull a boat a couple time a month also.
Old Feb 19, 2008 | 09:06 AM
YepIOwnA97Blazer's Avatar
YepIOwnA97Blazer is an unknown quantity at this point
2wd wheels have different offset/backspacing I thought.
Old Feb 21, 2008 | 07:04 AM
they do but I measured from the center of the rim and there is plenty clearance for 30's. They shouln't rub any because they are not that much wider than stock tires.
Old Feb 21, 2008 | 07:24 AM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
how about 235/60/16`s?
Old Feb 21, 2008 | 04:09 PM
drperry's Avatar
30x9.5s should fit... But I can't promise they will for sure...
If not, there's always the other optional factory tire size of 235/75/R15... There's a lot of selection in that size...
And your speedometer won't be out by as much, lol.
mirrorimij
Jun 8, 2019 03:34 PM
KidBlazer
Tires and Wheels
Feb 7, 2013 01:26 PM
lizzj70
Jun 23, 2010 06:57 PM
mx_579
Tires and Wheels
Sep 18, 2009 11:36 AM
Bad Ramer Jamer
Tires and Wheels
Sep 22, 2008 03:49 PM
