2022 Blazer AWD tire and rim size
Old Feb 4, 2024 | 08:39 AM
Cptdondo's Avatar
Cptdondo is on a distinguished road
Default 2022 Blazer AWD tire and rim size
I have a 2022 Blazer AWD 2LT. It needs new tires. The stock tires are 235/60R18 on I believe 8" wide rims.
I'd like to go to 265/60R18. Almost the same diameter, just a little wider and they should mount on 8" wide rims.
any comments, suggestions, advice?
I'd be running Falken Wildpeak AT4.
Old Feb 12, 2024 | 01:17 PM
El_Beautor's Avatar
I have no direct experience with the newer CUV style Blazers but I highly doubt those tires would fit without rubbing or other problems. According to the tire calculator I prefer, the 265/60/18 is 1.2" wider and close to 1.5" taller diameter. That's 4.87% taller, which leads to all sorts of challenges.
Check it out on 1010tires.com
The crossover type vehicles don't leave a lot of extra space for larger tires. I'd suggest you look for a size that's less than 3% different, and ideally 1.5% different or less than factory specs.
closer
Tires and Wheels
Jun 9, 2012 02:26 PM
aboll79
Tires and Wheels
Jan 7, 2012 11:28 PM
PaulO2288
Tires and Wheels
Sep 28, 2010 08:08 PM
fotijerina
Tires and Wheels
Dec 18, 2009 06:52 AM
sportking
Tires and Wheels
Dec 6, 2007 12:49 PM
