31" tires fit? & tbar help!
Old Aug 23, 2009 | 07:06 PM
Surferdude91's Avatar
Surferdude91 is on a distinguished road
Default 31" tires fit? & tbar help!
i have a 2000 4x4 s10 2-door blazer with a 2.50 T-bar crank lift in the front and i want 31" tires will they fit my truck? i do "mild" offroading so i think ill be good idk? somebody help
also on the t-bar lift on my right side the bolt is all the way turned before i messed with and i cant get it to lower at all its like stuck. so my t-bars are un even what should i do? if it would move id go back to a 2" tbar lift just to be safe
Old Aug 23, 2009 | 09:05 PM
AJBert's Avatar
Spray the bolt with PB Blaster and lower that front end down unless you really like to change out front end parts.
Old Aug 24, 2009 | 10:39 AM
matthew.chapman1's Avatar
matthew.chapman1 is on a distinguished road
They will fit, but will rub....i have 31's on my 2000 2 dr blazer and i adjustted the t-bar as well. I can drive right now, but any kinda of major turn they will rub, i am currently waiting for my 2" body lift to come UPS.
Old Aug 27, 2009 | 04:36 PM
tony991's Avatar
tony991 is on a distinguished road
I have 31" tires on my 2001 2dr blazer (not a zr2) with no tbar crank and the tires dont really rub...the only time mine do is if you turn the steering wheel all the way and you hit a bump!! lol
Old Aug 28, 2009 | 08:47 AM
Exactly what you don't want if you are going to drive a 4x4 like it was meant to be driven.
If you really want some information about lifting your truck go to the lifting section part of this forum...there is crazy amounts of info there to help you make your desicion...and a smalle 2" Bdoy Lift is not going to do any damge to any of your front end parts.
Old Aug 28, 2009 | 11:00 AM
oktain's Avatar
T-Bar cranks will cause pre-mature wear of front end parts, bring your front back down to a 1.5" lift then do a 2" body lift, you'll be safe that way and you'll be at ZR2 height-ish.
pmzusmc
Apr 19, 2011 05:44 PM
ComputerNerdBD
Feb 28, 2010 11:30 AM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
cide
Mar 23, 2009 10:57 AM
