31x10.50x15 duratrac tires on a 99 chevy blazer
Old Oct 1, 2011 | 09:47 AM
Brandon50394's Avatar
Brandon50394 is on a distinguished road
Default 31x10.50x15 duratrac tires on a 99 chevy blazer
Will 31x10.50x15 duratrac tires fit on a 99 chevy blazer with little or no rubbing?
Old Oct 1, 2011 | 12:31 PM
hertz20's Avatar
hertz20 is on a distinguished road
How close do the the tires you have on there now come to rubbing when you turn the wheel?
if it only has a little clearance now, you might need a lift or rims that have more of a offset outward.
Old Oct 1, 2011 | 02:14 PM
CenTexBiker's Avatar
CenTexBiker is on a distinguished road
if you have the tbars cranked a little to level off the truck
and use stock rims it will fit that is what I am running
however if you run rims that have less offset (meaning the stick out more) you will have to trim on rear of wheelwell
Old Oct 1, 2011 | 06:17 PM
xgiovannix12's Avatar
1.5 inch tbar crank 2 inch shackle lift would make them fit
Old Oct 18, 2011 | 10:37 AM
Blazer Spike's Avatar
Blazer Spike is on a distinguished road
I have 31x10.5x15 on my 03 blazer and I had to trim the fender and bumper trim to not rub. I'm at stock height right now still, but I also have aftermarket rims with 0 offset, so the rims and tires stick. With the t-bar cranked all the way I did not rub the fenders at all.
Old Nov 8, 2011 | 07:36 PM
1997 Gmc Jimmy's Avatar
1997 Gmc Jimmy is on a distinguished road
I have an all stock 1997 jimmy and the t-bars are not evan cranked. and im running 31x10.50 r15 all/T tires and there fine on normal driving. but they do rub on the frame and sway bar if i have the wheel all the way turned. off roading they do kinda bottom out a little easy but they sould work with out any trimming
It should be fine
Donny Ray Hedge
Lifting Tech
May 7, 2015 02:18 PM
Bigringtravis
Tires and Wheels
27
Sep 24, 2011 03:13 PM
Barney
Tires and Wheels
Jul 21, 2010 02:52 AM
aced411
Tires and Wheels
Feb 23, 2010 09:34 AM
PHATSPEED7x
Tires and Wheels
Jun 8, 2009 12:42 PM
