4x4 question
Old Dec 17, 2008 | 01:34 PM
Eman5pt0's Avatar
Eman5pt0 is an unknown quantity at this point
Default 4x4 question
well this weekened one of my tires went flat. i replaced it yesterday and the guy told me that on a 4x4 vehicle all 4 tires should be the same, now last year i replaced the front pass with a diffrent tire from the rest and this tire (front drivers sdie)is diffrent fron the other front and the rears, its push button 4x4 and i rarly use it. do i have to worry about the diffrent tires messing up the 4x4? note all 4 tires are the same size the only diffrence is the brands
any input
thanks
Eric
Old Dec 17, 2008 | 04:28 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: 4x4 question
No Eric, the BRAND of tire doesn't make any difference except for the possibility of a slight difference in handling charecteristics. What you DO NOT want to do is replacea tire or 2 on a 4WD when the others are BADLY worn or a different size. The effective diameter of all 4 tires need to be very close on a 4WD or AWD vehicle.As long as your other tires have at least 60% (or so) tread left, you should be fine.
Old Dec 18, 2008 | 04:47 PM
ptg327's Avatar
ptg327 is an unknown quantity at this point
i would recomend using your 4x4 once a month for about five miles to keep the fluid movin around. you dont want to be one of those people who dont use the 4x4 all summer long (most girls) and then when the first snow flake hits and you panic. you then reach for 4x4 and it dont work. not sayin it happens but im not sayin it dont.
Athlon2012
Dec 16, 2014 11:35 PM
razman
Feb 22, 2009 01:57 PM
sfesenko
Nov 30, 2008 08:55 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
