98 blazer wheel spacers
hello all, i have a quick question. i am no mechanic by any means, but i want to put on 1.5' wheel spacers in the back 2 wheels. i was just wondering which ones would work, i have a 98 blazer LS. i found these on ebay, and was wondering if they are any good and would work with my blazer, my rims are stock, but my tires are 1 size larger than what came stock.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
thanks in advance
thanks in advance
as long as u get sum for a 5 on 4.75 bolt pattern theyl work just fine, but y 1.5"? is that the difference from the front? it may rub if u go that wide. and as for them working good, they r made from aluminum....great. just put lock-tite on the nuts holding the spacer to ur rotor/drum. not the lug nuts holding wheel on! im running 2" on mine but thats because my front axle is 6" wider than my rear, so it makes up most the difference....lol
it may rub if u flex it with wider or bigger tires. i never had problems with rubbing with bigger tires but ive never put spacers on a stock rig. r u running stock wheels or aftermarket with a shorter backspacing? if ur running stocks u may not have any issues, but ive never ran spacers on a unlifted rig.
goodyear wrangler radial P235/75R15
rear passenger side:
![](http://i796.photobucket.com/albums/yy244/louismontana/IMG_0170.jpg)
front passenger side:
![](http://i796.photobucket.com/albums/yy244/louismontana/IMG_0169.jpg)
front drivers side
![](http://i796.photobucket.com/albums/yy244/louismontana/IMG_0173.jpg)
![](http://i796.photobucket.com/albums/yy244/louismontana/IMG_0172.jpg)
![](http://i796.photobucket.com/albums/yy244/louismontana/IMG_0171.jpg)
rear driver side
![](http://i796.photobucket.com/albums/yy244/louismontana/IMG_0174.jpg)
