backspacing
Old Oct 25, 2007 | 06:59 PM
Idriveachevy's Avatar
Idriveachevy is an unknown quantity at this point
Default backspacing
I dont understand the concept of back spacing, i wantto run 30 inch tires on my truck and i dont know what the backspacing for new wheels is. please help me out so i can understand it a little better
Old Oct 25, 2007 | 07:12 PM
jimmyboy's Avatar
jimmyboy is an unknown quantity at this point
Default RE: backspacing
your stock ones have 6" so you should stay as close as possible. jigg's synergy offroad has some from american racing. but if you want other ones then you can get ones with 4.5" bs and have a little scrub problems.
jimmyboy
i forgot the website for jigg's shop
http://shop.synergyoffroad.com/main.sc
Old Oct 29, 2007 | 04:29 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Backspacing is actually pretty simple. Its a depthmeasurement from the the inside lip of the wheel the mating surface of the hub. What the means is that if you were to make an imaginary line across the back surface of the rim and then from the center point of that measure to the inside face of where the wheel mounts to the hub, thats your back spacing. Stock on 4x4 blazers is 6", 2WD is 4". The less back spacing you have the more the tires will stick out, the more back spacing you have, the more the tire will move inward.
Old Oct 31, 2007 | 01:57 PM
WolfPack's Avatar
Is the backspacing the same on both axles? Im just trying to get a little wider stance and put some fender flares on, so am I correct in assuming that putting rims on with say a 4in BS would show another 2 in of tread?
Old Oct 31, 2007 | 05:07 PM
kankoon52's Avatar
kankoon52 is an unknown quantity at this point
yes the backspacing is the same for every wheel front and rear left and right. i am going to get 4.5" back spacing myself on my new rims because i want a little wider stance and i am also getting a body lift and shackles for the back. do you already have a lift or are you thinking about one? because with 4.5" backspace i would recomend atleast some shackles and cranking your t-bars up or you will rub with 31's if not prolly even 30's
Old Nov 1, 2007 | 09:01 AM
Jigg's Avatar
Jigg is an unknown quantity at this point
ORIGINAL: WolfPack
As long as you stay with 7" wide wheels. If you get 8" wide wheels, it'll be 3" of tread. 10" wide wheels, 5" of tread (all with 4" bs)
Old Nov 1, 2007 | 12:36 PM
TripleBlackBlazer's Avatar
Ok, how about this one? 8"wide wheel with 255mm tread (10.03937 inches) with 6" backspacing and 20mm offset. Will the wider wheel make the tire stick out 1" (for 1" more than stock 7" wheel and 235mm tread at 9.251969 inches) since it's the same backspacing as stock?
Old Nov 1, 2007 | 04:38 PM
Burlisonm's Avatar
Burlisonm is an unknown quantity at this point
uuuhhhhh.....yea ! [sm=smiley29.gif]
Old Nov 1, 2007 | 08:17 PM
WolfPack's Avatar
haha we're getting into some math problems here..
ccajun4real
Tires and Wheels
Nov 4, 2007 05:16 PM
kankoon52
Lifting Tech
Jul 27, 2007 01:10 PM
dirtyjersey
Tires and Wheels
Dec 5, 2006 09:16 PM
jimmyboy
Tires and Wheels
Nov 14, 2006 04:08 PM
SC_Rezahrektion
Suspension Tech
Jan 30, 2006 10:39 PM
