backspacing help!
Old Dec 16, 2009 | 11:30 PM
speterson1011's Avatar
speterson1011 is an unknown quantity at this point
Default backspacing help!
Ok so I'm kind of confused on one matter after reading some threads I just want to get something clarified. If I were to get 3" back spacing rather than 4.25" back spacing, which one would make the tire stick out of the wheel well further and make it look wider? 3" backspacing right?
thanks in advanced
Old Dec 16, 2009 | 11:53 PM
NVANZEE's Avatar
that is correct. The stock wheels are 6. So they would stick out 3in farther. I dont recommend doing that though. That will put a lot of force on you wheel bearings and the will wear on quickly. You will also have rubbing issues. My wheels are 4.5in BS which is the farthest you really want to go. I go through wheel bearings in 6 months but i have 33s and i beat on it a bit so that makes it worse.
Old Dec 16, 2009 | 11:59 PM
oktain's Avatar
Assuming your truck is a 4x4, 3 inch backspacing would be sticking 3 inches past where the stock wheel would be... That's because stock for a 4x4 is 6 inches...
I'm not sure what stock 2wd backspacing is, but it's around 4.25~4.5 if I'm not mistaken.
Old Dec 17, 2009 | 01:31 AM
old skool luvr's Avatar
i know the 1st gen 2WD's were 4". and a friend told me the 2nd gen's have more off-set then them, don't know why, or if it's 100% true.
what exactly are you trying to figure out peterson?
Old Dec 17, 2009 | 02:03 AM
Default reply
I just want to get the wider look, I have 31X10.5X15 on now with a 2" body lift and 6.5" fabtech susp lift and the tires look tiny so I'm thinking of getting 33X12.5X15 I have a ton of room. I was thinking about getting cragar soft 8 with 4" or 4.24" backspacing, I have a 99 2wd blazer base model
Old Dec 17, 2009 | 02:32 AM
where did you find that lift kit?
clw97bravada
Lifting Tech
Jul 3, 2010 02:28 AM
superdaveidaho
Tires and Wheels
Apr 21, 2008 09:14 PM
dirtyjersey
Tires and Wheels
Dec 5, 2006 09:16 PM
jimmyboy
Tires and Wheels
Nov 14, 2006 04:08 PM
SC_Rezahrektion
Suspension Tech
Jan 30, 2006 10:39 PM
