backspacing question
Old Dec 12, 2007 | 01:41 PM
TetanuSshot's Avatar
TetanuSshot is an unknown quantity at this point
Default backspacing question
i was going to pick up the US wheel series 94, 15" x 7", 5 x 4.75" rims, but they offer them in a 3.75" and 4.5" backspacing. I know the 4.5" b.s. is closer to stock, but i want a wider stance and am not sure if the 3.75" b.s will rub. I have 235/75/15's, but plan to go with 30x10.5's. anyone have any experience with these? also, i'm curious as to if rims with less b.s. put more strain on the bearings, bj's, etc. oh yeah, i have a '00 jimmy diamond edition 4dr, 4x4
Old Dec 12, 2007 | 06:13 PM
jimmyboy's Avatar
jimmyboy is an unknown quantity at this point
Default RE: backspacing question
it most likely will because that is almost half of stock b.s. if i were i would just get the 4.5 and maybe crank that tbars up an 1". it would look about the if not better because it wouldnt look like its squating with its wheels stickin out toooooooo far.
jimmyboy
Old Dec 12, 2007 | 09:54 PM
ryno's Avatar
ryno is an unknown quantity at this point
Same kind of question i already asked in a thread i started, but do you think if i do the same wheels as TetanuSshot, i could fit 30's if i just crank up the torsion bars?
Old Dec 13, 2007 | 06:55 PM
jimmyboy's Avatar
its might be a tight fit and you most likely scrub the fender. if you crank them close to 1.5" or so it may not scrub that much.
jimmyboy
Old Dec 13, 2007 | 10:20 PM
ryno's Avatar
Would that se my front up higher than the back?
Old Dec 13, 2007 | 11:52 PM
thegr81's Avatar
If you crank the t-bars in the front and do nothing with the back then yes it will raise the front above what the rear is.
Old Dec 14, 2007 | 12:00 AM
mdehoogh's Avatar
ORIGINAL: thegr81
unless you have an uber-raked blazer like mine and even after cranking the tbars, im still barely level...
Old Dec 14, 2007 | 08:45 AM
sooooo, stock tires on the 4.5BS rims will rub without cranking the tb?
mross45640
Tires and Wheels
Apr 15, 2011 07:36 AM
shady677
Tires and Wheels
Mar 19, 2011 04:00 PM
BlazinAmazin
Tires and Wheels
Dec 12, 2010 10:35 AM
Blazercrazy
Feb 16, 2009 11:49 PM
SC_Rezahrektion
Suspension Tech
Jan 30, 2006 10:39 PM
