question about backspacing
Old Apr 11, 2011 | 08:29 PM
mross45640's Avatar
mross45640 is on a distinguished road
Default question about backspacing
i am looking at the craiger soft 8,i found on here the factory backspacing on 99 jimmy is 6" but i can't find any with that backspacing.what is everyone else running on these wheels?it is a 4x4 thanks mike
Old Apr 11, 2011 | 08:43 PM
69chevelle's Avatar
69chevelle is on a distinguished road
depends how wide the wheel is
Old Apr 12, 2011 | 06:05 AM
mross45640's Avatar
Oh a 15x7
Old Apr 13, 2011 | 09:09 PM
98chevyblazer's Avatar
98chevyblazer is on a distinguished road
I have the same question I was looking at 15x7 rims with 235/75r15 tires on them will they rub against the frame in the front when I turn? And does anyone have 15x7's on their blazer?
Old Apr 13, 2011 | 09:46 PM
mdehoogh's Avatar
98chevyblazer, most Blazer's come with either 235/75r15 or 235/70r15 on 15x7 wheels so no, you won't have a problem.
mross45640, I think the highest backspacing I've seen on cragar 15x7's is 4.5" Unfortunately, there aren't many wheel options with the correct 6" backspacing and 51mm offset. I am running 15x7 with 4" backspacing and really like the look of the slightly wider stance. You shouldn't encounter any problems if you're using a stock size tire. I went up to 31x10.5 and had to trim my fenders as well as crank the tbars some in order to have enough clearance to turn properly.
Old Apr 13, 2011 | 10:31 PM
So I shouldn't have a problem even though mine on now are 15x6?
Old Apr 13, 2011 | 10:40 PM
s14sh3r's Avatar
Yours should be 15x7 unless someone has swapped them out.
Old Apr 14, 2011 | 05:44 PM
mross45640's Avatar
Do you have any pics with the wheels I could see?
Old Apr 14, 2011 | 06:21 PM
s14sh3r's Avatar
I'm assuming you're talking about mdehoogh's truck. Here's his build thread, the pics you're after start on page 4: https://blazerforum.com/forum/builds...8-build-50833/
Old Apr 14, 2011 | 07:42 PM
mdehoogh's Avatar
Yeah there are some pics in the link above.
Here's another pic that kind of shows the stance
