BFG AT 33x9.50x15??
Old Oct 10, 2011 | 11:21 PM
mikejsansone's Avatar
mikejsansone is on a distinguished road
Default BFG AT 33x9.50x15??
Is anyone running these? Was looking to pick some up for my 2001 4x4 4 door. Running 2 inch body lift and 2 inch shackle/t-bar crank for lift right now. Running 30x9.5's right now with plenty of space, was wondering if anyone could post up some pictures of 33x9.5's. Does anyone know how the stock rims might fare with these or would it be better to go with something of a more negative offset to fit? Looked around the threads and really couldn't find anyone with 33x9.5 specific info.
Thanks
Old Oct 11, 2011 | 04:57 AM
warthogdriver's Avatar
i have 9" inches of lift and clear 33's with trimming...i dont think they will fit with only 4" lift
i run 33/15
Old Oct 11, 2011 | 05:55 PM
NVANZEE's Avatar
yeah i have the same setup warthog has. And mine rub occasionally offroad. Also do they even make a 33x9.5? They would look kinda funny if you ask me. A friend of mine has 34x10.5 and those look kinda goofy since they are so narrow for the height.
Old Oct 11, 2011 | 11:14 PM
AJBert's Avatar
I've got 33X10.5's on the ZR2 with a 2" bl plus 2" shackles and a tbar crank with moderate trimming.
I STILL rub at full flex on the rear of all four flares. This with the stock rims. I'm thinking you might be a bit worse off than me.
And that includes if you never go off road yet hit the occassional speed bump at your local mall.
Old Oct 12, 2011 | 07:08 AM
Bigringtravis's Avatar
Bigringtravis is on a distinguished road
Plus the gearing... you would need at least 3:73s or maybe even 4:10s to keep any kind of acceleration.
Just my .02
Old Oct 13, 2011 | 06:55 PM
Sorry for the late response. As to gearing, already running 3.73s. As to the narrow tires, I don't mind the pizza cutter look, and will be doing minimal wheeling with this setup. Also, it definitely wouldn't be for mudding, more trail running and light rock crawling. In the process of a dual D44 build. I mean realistically, aren't the 33s just 1.5 inches more around every point on the tire compared to the 30s since the only difference is the diameter? That's why I was hoping for pictures but I know that barely anyone runs these spec tires.
Donny Ray Hedge
Lifting Tech
May 7, 2015 02:18 PM
Brandon50394
Tires and Wheels
Nov 8, 2011 07:36 PM
Barney
Tires and Wheels
Jul 21, 2010 02:52 AM
Macbass05
Tires and Wheels
16
Jan 13, 2008 11:25 AM
Taymacjack
Tires and Wheels
Aug 22, 2007 06:33 PM
