bigger tires in rear??
Old Mar 22, 2011 | 01:22 PM
avelate63's Avatar
avelate63 is on a distinguished road
Default bigger tires in rear??
ok, so i know this is a little out of ordinary (considering i've almost litterally found nothing about it anywhere), but i have a 03 2dr RWD that i thought the idea of putting on larger wheel and/or tires on the rear. basically looks and traction are the pros i see. and comments/suggestions??
thanks guys
Old Mar 22, 2011 | 03:55 PM
s14sh3r's Avatar
As long as your trucks not a 4 wheel drive, it really won't hurt anything. The only thing it will do is change your caster angle slightly. As long as you're not going too huge, you probably won't even notice.
Old Mar 22, 2011 | 03:57 PM
Benedict1337's Avatar
I think bigger tires look good in the rear, you can probably fit 265's in the rear and keep the 235's up front
Old Mar 22, 2011 | 05:39 PM
rriddle3's Avatar
Personally, I've never cared for the idea. What if you have a flat - does the spare match the front ones or the rear ones?
Old Mar 22, 2011 | 06:27 PM
Two spare tires would take care of that problem! I'd be more concerned with the speedometer not indicating correctly.
Old Mar 22, 2011 | 09:05 PM
old skool luvr's Avatar
if you're going after the ol' raked hot rod look, then you've nailed it.
while i like the look-on the right application-it's really up to you, since you're the one who is gonna be driving it every day.
MacArthur
Tires and Wheels
Jun 14, 2011 08:51 PM
2001blazer
Street N Strip
Aug 28, 2006 03:08 AM
flowmasta
Jul 30, 2006 02:39 AM
davtak
Tires and Wheels
Jul 15, 2006 11:57 PM
SEDOC
Feb 16, 2005 03:56 PM
