biggest size that'll fit without rubbing?
Old Aug 19, 2009 | 03:55 PM
AsherHimself's Avatar
AsherHimself is on a distinguished road
Default biggest size that'll fit without rubbing?
I have a 95 2dr with no lift. I'm probably needing to get new tires and i'm wondering the biggest that'll fit without any rubbing or problems?
Old Aug 19, 2009 | 04:19 PM
Sisk's Avatar
Doing some reading or a quick search would have found your answer .
The biggest on stock I believe is 30x9.50R15 (currently what I have). If you go any bigger then 30's, you're looking at trimming
Old Aug 19, 2009 | 06:55 PM
oktain's Avatar
Look at your tires size, see if its a 70 series or a 75, 75 is the biggest, that'll be equivalent to the dimensions Sisk just gave.
Old Aug 19, 2009 | 11:20 PM
teddybeer21's Avatar
teddybeer21 is an unknown quantity at this point
i have bfg 31x10.5 15 mudd terrain on stock rims stock hight and i had to do alittle inner fender modifications ( beating the hell out of it with a hammer) but its not noticeable and on the back the go right on no "modifications" haha
Old Aug 19, 2009 | 11:39 PM
NVANZEE's Avatar
it also depends if you do any off roading. You might be able to fit 31s with slight rubbing but if you take it on the trails say goodbye to your fenders
Old Aug 21, 2009 | 06:23 PM
calicojack's Avatar
calicojack is on a distinguished road
i'm going to chim in here with a noob question as well.
31" tires will fit on a stock 96 rim? unlike the OP i'm thinking about a 2" body lift on my 96, and have no clue when it comes to tires.
Old Aug 22, 2009 | 07:47 PM
Sisk's Avatar
You can fit 31's on a stock rim, yes (go with what NVANZEE has...31x10.5 15). You would want to go with that 2" body lift first though to prevent rubbing or trimming.
simmonsnick
Tires and Wheels
16
Jan 29, 2017 11:55 AM
thedopeshow912
Lifting Tech
14
Mar 10, 2010 01:42 PM
D_Beezy18
Tires and Wheels
Mar 2, 2009 09:26 PM
butters
Tires and Wheels
Jul 15, 2008 09:47 PM
cbright890
Tires and Wheels
Jan 5, 2008 07:17 AM
