Bolt pattern
Old Apr 5, 2009 | 02:02 AM
doublearon's Avatar
doublearon is on a distinguished road
Default Bolt pattern
I am looking for the bolt pattern for a 1999 Chevy Blazer. I believe the stock wheel is a 15x8. Any help would be greatly appreciated.
Old Apr 5, 2009 | 02:10 AM
WolfPack's Avatar
Nope.
Stock wheels:
4x4 -- 15x7, 6'' backspacing, 5x4.75 bolt pattern
4x2 -- 15x7, 4'' backspacing, 5x4.75 bolt pattern
Hows Kuwait?
Old Apr 5, 2009 | 03:39 AM
doublearon's Avatar
Default a 15x7?
Wolfpack,
man, Iwas almost certain it was a 15x8. Have another question for you then. It is hard to find the wheels to go with my 5'' lift I am having installed next week. Could I change out my hubs and brake disc to accomodate a 5x 4.5 bolt pattern? The reason I ask is the Mickey Thompson side biters look really good. but they do not make them in in the 5x 4.75 bolt pattern.
I like your truck. My friend here is a huge NC State fan so he is all about it.
Old Apr 5, 2009 | 07:54 AM
doublearon's Avatar
Kuwait is very boring by the way. Looking forward to my vacation back home in Florida next week.
Old Apr 5, 2009 | 04:03 PM
WolfPack's Avatar
Yea the 5x4.75 is a little limited
You can get spacers/adapters to go from 5x4.75 to 5x4.5. The only issue is that since stock backspacing is 6''...most wheels will be in the 3.5-4.5'' BS range. SO...the lower backspacing gives you a wider stance, then, when you put spacers on, the stance gets even wider. Some people like the real wide look, but it is also harder on your bearings and steering.
As far as actually changing out the hub..Im not entirely sure that would be a good idea even if it did work
And 15x8s will work fine..no need to stay with a 15x7 unless you like knowing you have stock specs to the very end
Old Apr 5, 2009 | 06:30 PM
bandidolenny's Avatar
You can order aluminum wheels through places like Summit Racing with just about any specs that you want but they are not too cheap.
Old Jul 8, 2012 | 09:42 PM
iamchevyman5's Avatar
iamchevyman5 is an unknown quantity at this point
so from what i've researched on this thread and on the rest of the site where threads were relevant but closed, These camaro wheels WOULD work, correct?
CAMARO WHEELS 98-02
Let me know,
~Dan
Old Jul 21, 2012 | 04:05 PM
TrTl's Avatar
TrTl is on a distinguished road
I have those wheels on my 99 Jimmy 4x4. You may need Camaro lug nuts for the caps to fit, I did. The wheels fit and look good.
Old Jul 21, 2012 | 04:20 PM
CraigSnedeker's Avatar
Yep, they fit!
clutch
Tires and Wheels
17
Feb 3, 2007 04:29 AM
4x4blazin
Tires and Wheels
Dec 14, 2006 10:53 PM
sledneck16
Sep 19, 2006 08:43 PM
dubluj
Dec 12, 2005 02:09 PM
Grkblazer
Tires and Wheels
Sep 4, 2005 02:54 PM
