Bolt pattern
Wolfpack,
man, Iwas almost certain it was a 15x8. Have another question for you then. It is hard to find the wheels to go with my 5'' lift I am having installed next week. Could I change out my hubs and brake disc to accomodate a 5x 4.5 bolt pattern? The reason I ask is the Mickey Thompson side biters look really good. but they do not make them in in the 5x 4.75 bolt pattern.
I like your truck. My friend here is a huge NC State fan so he is all about it.
Yea the 5x4.75 is a little limited
You can get spacers/adapters to go from 5x4.75 to 5x4.5. The only issue is that since stock backspacing is 6''...most wheels will be in the 3.5-4.5'' BS range. SO...the lower backspacing gives you a wider stance, then, when you put spacers on, the stance gets even wider. Some people like the real wide look, but it is also harder on your bearings and steering.
As far as actually changing out the hub..Im not entirely sure that would be a good idea even if it did work
And 15x8s will work fine..no need to stay with a 15x7 unless you like knowing you have stock specs to the very end
so from what i've researched on this thread and on the rest of the site where threads were relevant but closed, These camaro wheels WOULD work, correct?
CAMARO WHEELS 98-02
Let me know,
~Dan
CAMARO WHEELS 98-02
Let me know,
~Dan
dubluj
Dec 12, 2005 02:09 PM
Grkblazer
Tires and Wheels
Sep 4, 2005 02:54 PM
