Dumb question
Old Feb 1, 2007 | 04:13 PM
Madwahoo's Avatar
Madwahoo is an unknown quantity at this point
Default Dumb question
I noticed a lot of people trying to keep the same circumference wheel and tire combo so the speedometer reads correctly. What needs to take place if this number is off?
Old Feb 1, 2007 | 04:16 PM
Default RE: Dumb question
It depends on what year we're talking about. On the older trucks, it'll take a different gear in the tail shaft on the transmission. On the newer ones with the first iteration of electronic speedos, it may take a different reluctor ring in the tail shaft of the transmission. On the newest, all it takes is a different scale factor in the PCM.
Old Feb 1, 2007 | 04:18 PM
rabbit0102030's Avatar
rabbit0102030 is an unknown quantity at this point
I'm no expert, but I would say speedometer recalibration. I think they sell a computer plug-in module at JCWhitney.com that can help you to recalibrate it yourself.
Old Feb 1, 2007 | 11:01 PM
Hanr3's Avatar
Like swart said. Plus I would like to add.
Depends on how much off were talking?
If your going to 33" or larger tires. You should also replace the ring and pinion gears in each axle too. If you dont, you WILL shorten the life span of your tranny.
jeff6898
Jun 15, 2008 06:21 PM
ryanpip18
Tires and Wheels
Feb 14, 2007 01:16 PM
XBlazer01
Jul 7, 2006 05:37 AM
silverjimmy95
Nitrous, Super Chargers, & Turbos
Feb 27, 2006 09:59 PM
blazerxtreme1
Feb 2, 2006 02:11 AM
