How much is speedometer off with 31" tires?
Old Feb 20, 2010 | 10:48 AM
uncle larrys oranges's Avatar
uncle larrys oranges is an unknown quantity at this point
Originally Posted by TripleBlackBlazer
It only really seems to be noticeable (for me anyway) above 60. Of course my sidewall is only 5% taller than stock (235/75's instead of stock 235/70's) so when I'm going 60 on the speedometer I'm actually going 63 and change. The more you deviate from your stock size the more drastic the difference will be. I don't think it's possible your speedometer showed 35 and you were actually doing 50, that's quite a gap!
Well I do know my speedometer said more than 35 I just don't know exactly what it said because I was a little distracted by the cop.
Old Feb 20, 2010 | 04:54 PM
MrJP's Avatar
MrJP is an unknown quantity at this point
In my opinion, the easiest solution is a GPS. They aren't affected by tire size.
Old Feb 20, 2010 | 05:59 PM
neo71665's Avatar
My speedo was 5mph slow with stock tires. I agree with the GPS, I don't ever look at my speedo for the speed anymore.
Old Feb 27, 2010 | 04:39 PM
515Blazer's Avatar
515Blazer is on a distinguished road
First of all if you switch to 31s from 235/75/15s then the speedo will read 7% slow, and to all the ppl that said there's is 8 off or 10 off of whatever, you speedo can not be off by the same speed all the time like that it is a percentage. if you say it 8 off then it would have to be 8 off at 0mph and thats not possible. at 7% slow you would be doing 65 when your speedo said 60, and when you got pulled over for 50 in a 35, you speedo should have said 47mph
Old Feb 28, 2010 | 08:57 AM
515Blazer's Avatar
and when you go to check your gas mileage you have to mutiply it by 1.07 for it to be accurate
Old Feb 28, 2010 | 11:55 AM
NVANZEE's Avatar
How did you calculate that? It would nice to know my actual MPG. I have 33s.
Old Feb 28, 2010 | 12:17 PM
people have said that the odometer is off as well now. Is that in my favor (says less miles than actual) or against me (says more miles than there actually are)?
Old Feb 28, 2010 | 01:51 PM
NVANZEE's Avatar
it will show less miles than actual
Old Feb 28, 2010 | 02:37 PM
Tire size calculator - Miata.net
Put in your stock size and then your new size and it'll give you how much of a difference there will be.
Old Mar 1, 2010 | 12:40 PM
515Blazer's Avatar
for 33s your speedo and odometer will be off by 14% to calculate for gas mileage as usual then mutiply your answer by 1.14 you get your actual.
