i need suggestions!!
im looking to buy new tires and rims, i know for sure im gonna get 15" rims with 4.5" backspacing so i get that wider stance. my question is, what is the biggest tire size i can put on without rubbing. im not lifting it in any way, pure stock. thanks in advance
shouldve mentioned, its a 95 4x4 2 dr. non zr2. i want a all terrain or mud terrain.
will a 30 x 10.50 fit with no rubbing or clearance issues?
30x10.50 would be fine with stock wheel backspacing. but if your not lifted your gonna have a hard time getting the stock size tireto not rub. bc i have a 2in lift and running 4in backcpace and i almost rub the fenders with my 235/75 r15. i could be wrong. i can take some pictures of mine 2morrow to show you how close mine are to rubbing.
that would b cool, thanks
ORIGINAL: BGwood88
but..
x2 on rubbing issues with 4.5' backspacing. 235/75/15 is about the biggest you'll clear with 4.5' backspacing. I have 30x10.50s on 4.5' bs rims, and rub offroad with a 2' body lift, and 2' shackles/tbar lift.
what about 29 x 11.5
i found a set of 215/85/15's but i think that would be a really narrow tire and might look a little goofy with the added backspacing, what do you guys think? it's 28.7" in diameter which is only .7" taller than my stock tires but it only has a tread pattern of 6.6". that skinny would be good for gas mileage, snow, and mud. but i dont really go off roading very often? i dont know, help me out guys. i wanna decent looking urban 4x4
215s will look silly. And no 29.5x11.5 will not fit. The biggest is 30x9.5. the end.
